What happens when a speaker has a DAC?
Acerun
San Francisco
I'm looking at purchasing the Audioengine A2+
It says it has a 16-bit DAC inside. Can anyone help me understand how that works?
Would it be correct to assume that if I use Bluetooth it would use the DAC and if I hardwired it would bypass the DAC? Otherwise the signal would pass through a high quality DAC, then be put through the speaker's 16 bit DAC? That doesn't sound right.
Can anyone shed some light on the signal logistics?
Thanks!
milan616
USB and BT should use the DAC, analog in should bypass.
Racheski
Chicago
Don't mean to rain on your parade, but the A2+ kinda suck. I purchased and returned them ~1 year ago because I wanted budget wireless speakers. They don't get very loud before distortion, and failed to adequately fill a small office with sound. You will need a subwoofer for decent bass as well. If you can scrap together an extra $100 go with the Vanatoo Transparent Zero - they are a massive upgrade.
Acerun
Acerun
San Francisco
Did you try to EQ them along the lines of amir's suggestions for the a5 Plus and using a hightg quality DAC? I'm looking for a pair of white very small speakers for the nightstands of my bedroom... Critical listening not required.. more like billiards night with the kids to Don't Start Now...lol.
The only other speakers in the ballpark with some sort of Amir review are the Fostex PMO.3
Racheski
Chicago
Did you try to EQ them along the lines of amir's suggestions for the a5 Plus and using a powerful enough DAC and amp? I'm looking for a pair of white very small speakers for the nightstands of my bedroom... Critical listening not required.. more like billiards night with the kids to Don't Start Now...lol.
Negative - I didn't even know what EQ really was back then before I joined ASR :)
They are very very small so if space is an issue they make sense, but expect to pay a penalty in loudness and lack of bass. They certainly won't do Dua justice.
Edit: Just throwing out an idea...what about the HomePod? I have no clue how it sounds, but it comes in white.
Chrispy
PNW
How does a dac become "powerful"?
Acerun
Acerun
San Francisco
Yes space is at a premium.. 6x4 is highly compelling on nightstands on either side of the bed. :)
Jim Matthews
Taxachusetts
For casual listening over Bluetooth, have you considered JBL portables? They're not particularly accurate, but they generate significant volume (bass, even) from a small form factor.
Colonel7
Maryland, USA
Have you considered the Google Nest Audio? It fits your size parameters and background listening use case. Good spin for the price too as measured by @napilopez here. $99 per or $20 off for 2. Guessing you can make them play stereo as an option
Acerun
Acerun
San Francisco
More detail:
The original idea was to use either hard wired phone to E30 (or) phone to hard wired Sonata HD Pro to L30 to powered speakers.
Alternatively, phone to Qudelix 5k BT to L30 to powered speakers.
Open to all ideas though.
Acerun
Acerun
San Francisco
But also be interested in if anyone wanted to stand up for the audioengine A2+ or Fostex PMO.3
Acerun
Acerun
San Francisco
I listened to them both side by side and subjectively I prefer the Audioengine A2+ to the Fostex PMO.3. I used Amir's EQ for both. A2+ had more bass and better mids. Fostex was brighter and thinner but not terrible by any means.
Dua sounds terrific and they look great in white. :)
Acerun
Acerun
San Francisco
Audioengine A2+ a nice fit for nightstand set up :)
Acerun
Acerun
San Francisco
I've had a complete change of heart. For $290 after taxes...this was a bad investment...bound for landfill. I even tried the HD3...bad. Returned them all. Considered Vanatoo or iLoud.
Bucked up for something that could last 15 years or more (hopefully). German built Eve Audio SC203. I had great success with the German built RME ADI-2 DAC.
tili
buyers remorse land
does amir have EQ settings for A2+?
Acerun
Acerun
San Francisco
No, just the larger one. I never got mine to sound very good. Tried Eve Audio. Eventually bought the micro monitors on sale for $199 and they sound good.
carewser
Victoria, BC
I really wanted a pair of A2+ as well but I just couldn't justify $400/pair Canadian for a pair of 30 watt satellite speakers that only go down to 65hz so I waited and found a mint used pair of A5+ speakers for a lot less but being the basshead I am even the A5+ didn't provide me with the bass I needed so I also bought Audioengine's subwoofer for full price
As far as DAC's go, all I know about them is, they stand for digital to analog converter and I know at least one pair of my many pairs of speakers have a DAC built in
