Low frequency pressure, yes maximal against the wall in an angle,where a corner bass trap can be used.
Diffraction or reflection, it's not the same thing.
Diffusion : works for one direction. For others direction, you generate phase accidents.
And
Quote: Originally Posted by diffusor.com ➡️ I have had enough of your and Northward's absurd and condescending comments about SMT diffusors and its customers. http://www.gearslutz.com/board/showp...2&postcount=25 Calling well-known mixers, monitor manufacturers and world-famous musicians...
gearspace.com
And
https://gearspace.com/board/showpost.php?p=15526228&postcount=15
Your room like my room are little room.
The plolyclindrical diffuser do not cause this kind of problem.
You must treat the room completely or do like me: separate the room in two part with mobile walls (I have choosen plexiglass in10 mm.
20"/5000 rayles give an absorption of 0,5 at 50 Hz. An easy way to treat a room, you have the place.
You will think after to setup the decay time.
As said André Vare 90 % of brainstorming and 10 % of build.
