Yorkshire Mouth
Before you answer, yes we know.
We know the speakers you have are important.
We know the room dimension ratios are important.
Okay, okay, okay.
But we also know that, if you are in a massive hall, your chances of amplifying your speakers enough without distortion, and the impossible echos, will not be ideal. Not to mention unnecessarily expensive.
And if your room is too small, you simply aren’t going to be able to get bass down to 20hz without all sorts of problems.
And no one wants to sit in a box room or a hall anyway.
So what’s the ideal room size, given that you want to use standard, domestic hi-if kit?
Put another way, imagine you’ve won the lottery. You’re not a multi-billionaire, but you have enough to build your own large, detached house, with as many bedrooms as you’ll reasonably need, a lounge, kitchen, bathrooms, etc., and will have enough money left to add one extra room, and buy the best hi-fi kit. And the architect designing it has asked you for dimensions.
Okay, okay, okay.
