Wanted: Proof of multiple subs and sub EQ
Actually this has been bugging me for a while. How DO you measure bass decay in a room? If you take the measurement from one position, it won't give you a true picture - peaks take longer to decay, and nulls decay almost immediately. You can get REW to "normalise to peak at each frequency" which helps, but it's still not a true picture. Obviously you have to measure over a wider area, but how do you know if those positions are representative? And if you average them, you lose timing information, so you can't view waterfalls or spectrograms any more. @Bjorn I would love to hear your answer.
If you want to look at primarily time of ringing, a burst decay is good to use.
Example with untreated and half way treated.
For resonances, I generally prefer a waterfall. Considering bass is not only heard but also felt I normally measure at feet level, stomach level and at ear height and look at them separately.
It's good to look at the graph for the lower midrange here too. The most audible resonances are really above the sub frequencies, and is one of the reasons why DBA or multiple subwoofer approach doesn't reach the highest level alone. Not many have heard a really well treated room, so they don't know what they are missing out on. I focus more on mid bass, upper bass and low midrange if I have to make compromises in a design.
Thanks. Where do you take your measurement from?
REW has a burst decay display, but it looks nothing like yours.
I haven't used this view mode much, and really don't understand why the "smearing" appears to steer over time to the right of the graph. Maybe it's just an artifact from the maths used to draw the graph? I dunno.
Go to the Waterfall tab, it's there, that's the Spectrogram you have here.
I sometimes forget the different graph window views can have same named "view modes". Smearing or decay also steers to the right when using the burst decay view mode of the waterfall plot.
I have two subs in my setup, which I run in mono to even the frequency response at the listening position. Here are some plots to show how these subs play separately and together. This was measured with REW at the listening position. I show decay plots, as I think they are slightly more informative than waterfalls.
Frequency response:
Sub1 Decay:
Sub2 Decay:
Sub1 + Sub2 Decay:
Look at the particularly nasty peak at about 45 Hz, which in fact is a degenerate resonance of two separate modes. As you can see, the two subs - which are playing the same signal - are able to bring down this peak.
Note that this is not the final response of my system. I’m using more DSP later in the signal chain to smooth things further. Here I just wanted to show the isolated effect of multiple subs.
Also note that I have verified that this works by listening to burst test tones, so it’s not just about visually appealing plots. The test tones were from this post by @KSTR:
Bjorn's software plots a completely straight line... Which makes me suspect it's just an artifact of how it's drawn in REW.
It could be.
We would only know if we could see Bjorn's parameters, filtering, etc.
Indeed, smoothing peaky in-room response seems to be one of the benefits of having multiple LF sources spread out.
It also could be normalized to peak, REW shows similar if the option is on.
I think there are less differences between your plot and Bjorn's second plot than you think. His plot was from ~10/20 Hz to ~120 Hz. vertical scale range is 60 dB, and time scale range is 60 periods.
Yours is 23 - 600 Hz, color scale range 40 dB, and time scale 32 periods.
I think the skewing of the plot to the right is because the time scale is in periods. 30 periods at 600 Hz is the same amount of time as 3 periods at 60 Hz.
