Want to buy a player that shows album covers - any suggestions?
Agoura Hills, CA
Budget - $1200
I have many CDs that I have started to rip to flac.
I don't want to leave my PC on all the time.
I want to find a player that will play from a a network attached storage drive.
The player must show album covers.
It would also be nice if it played from a USB drive, but this is not a dealbreaker.
Does not need to be portable.
Does not need to include a DAC.
So far, this looks like it might be the best thing for me:
- Cambridge Audio CXN (V2)
Jimbob54
I have the CXN V2- good bit of kit. What will be the likely distance between you and the display? I'm sat about 8ft away and I can make out obvious covers but a lot just becomes a blur of colours. Not the greatest of displays.
I have never tried it with a NAS/ DLNA set up though. I use it (seamlessly) with Roon and streaming services.
engineeringDynamo
Agoura Hills, CA
Thanks for the reply. So far, the CXN-V2 is looking like my best option.
I like that it includes internet radio.
Sitting on the couch, I am 11 feet from the display.
It's funny that cheaper portable players have bigger and better displays than the CXN V2.
Also, the V2 has been out for almost 2 years. I wonder when there will be a V3?
Jimbob54
I'd say the display was too small for that distance
The actual album cover is roughly a 3cm square on a less than crystal clear display. The rest of the window is for text. Great kit though and you can always view/ control with the phone app
KR500
Mac Mini to your tv ?
My album covers are all on there and the Mini is only turned on during use. Zero operation noise
Ralph_Cramden
Raspberry pi with a screen?
Yep.
Morpheus
E.C
Budget - $1200
Check Cocktail audio, they have largish displays in all their current models, and the cheaper ones are within your budget.
Marc v E
The Netherlands (Holland)
Just as a side note: I tested a 2000,- euro streamer at home. It was the same as a 35,- chromecast. Same with the pi streamer at 60 euros. And the pi can play from usb too.
I have a 1500,- euro Nad dac pre that performs less than a Topping dx7pro for 600,-.Food for thought.
raindance
A universal bluray player and a computer monitor or TV is what I would use. It's the only alternative to the Pi + display.
Jim Matthews
Taxachusetts
I'm very happy with my Bluesound Vault 2.
It's not the last word in resolution, but it works and the BlueOS is stable.
Morpheus
E.C
Budget - $1200
(V2)
If you lived in Europe, there are the Audiophonics readymade Pi players/streamers that come in a nice case and a very readable Pi screen with your OS of choice, for less than half of the Cambridge or the Cocktails, or even less depending on the versions ( several available, with/without Dac, etc) ... Don't know how that value proposition holds when you import though...
MrDogg
Following, does anyone have a link to a video that shows you how to set up the pie to a screen to display album artwork? I just got mine set up with moode but that's about it but that's about the extent of my knowledge
Zensō
California
