jimijoeb
Ok, make sense for your decision. I saw design, nice short and sleeved cables and lot of orange. It reminds me trend in PC builds with cable sleeving.Radiations are mainly done by the cables, and by a few components that happen to be on the other side from the heat sink.
I tested both positions of the SMPS1200 for my amplifiers. Measurements were exactly the same but one of the 2 positions was allowing both better cable management and better air flow.
That was exatly my thought for best design. Al is good for statics, but not for magnetics. That piece of steel probably coud help a lot and add few $ to BOM, only downside is weight. I would also avoid stainless steel, as not all of them are magnetic.I used to think that but I found out that the aluminum used in heatsinks is weak for magnetic shielding, almost like air.
https://en.wikipedia.org/wiki/Permeability_(electromagnetism)#Values_for_some_common_materials
Steel is a cheap solution, just like Apollon did with the Purifi Mini.
Edit: Also noticed that it seems like they used short wires from PCB to XLR connectors to prevent mechanical issues.
