Variable line out (TV) question
nygafre
Cheers,
I have a very(!) newbie question. On my Sony LCD TV I have a line out, which I can either set to ‘fixed’ or ‘variable’.
If using it w/ variable setting, I can control the volume by the TV remote. Is the variable line out then acting as a pre amp? (Or something else.. I guess that would be ‘variable line out’).
I am asking because I was contemplating to connect the TV to a power amp if it is actually functioning as a preamp.
fpitas
Northern Virginia, USA
Probably variable line out. As long as you can control the volume, most likely it will work ok.
nygafre
nygafre
Ok, thanks. Can you explain the difference between variable line out and a pre amp?
Do I risk anything by connecting the poweramp to the variable line out?
fpitas
I know nothing about TV sound like that. But if the volume can be adjusted, you should be able to use it.
These days, a "preamp" is often just a switch box, unless you need special amplification for a thing like a phono cartridge.
JayGilb
West-Central Wisconsin
The variable line out is using the software of your tv to control the line level signal going to your poweramp and is acting as a preamp.
A preamp is a device which controls/modifies the line level signal prior to it going into a poweramp.
The risk of using your tv as a preamp would be the possibility of someone switching the tv back to fixed level output and possible damaging components and speakers downstream.
fpitas
Good point. I wonder if one can fix it in variable mode.
Beershaun
Fixed line out should still be fairly low level as it's intended to go to something like an AVR or pre amp where you would use an external volume so I suspect you are ok. But it would be good to see what the specs say about the fixed line out voltage.
nygafre
nygafre
Thank’s for the clarification!
Yes, and that sure leaves me a bit nervous. It is quite tricky navigating to the exact settings/setting page, so I don’t believe anyone random would change the settings (only me in the household too :p).
But I am worried because at some point somethings always happens with these things. Could be as simple as resetting the TV setting, where I forget all about the settings myself.. feels risky.
Yes but not easy to find.. hmm
thecheapseats
Los Angeles refugee
that ^^^ is most importantly good cautionary advice...
