Using power amplifier to drive headphones, adapter.
Balle Clorin
Sorry do not know why pictures end up in the wrong place.
I have this cute unused tube amplifier I want to convert to a headphone system. With Chromecast as source and Roon I could correct flaws in the frequency response too…
It may measure like crap and sound like tubes, but it looks kind of cute. It actually did sound OK on my Audio Physic Virgo II, as long as level is low. I will be using my crap headphones Grado SR125 bought 25 years ago..
Now I just have to wait for the adapter to arrive…
klipping-jpg.130643
Clipping at 10Watt 8 ohm
10khzsq-jpg.130642
10kHz.
tubeampresponse-jpg.130641
some want 450 dollar for a box with 4 resistors and som connectors to adapt power amp output to headphones.
Ebay for 50usd , so I bought this one . If it is not good I can modify it I guess.
DIY variant
  • Compact and Portable:At just 70x115x25mm, the adapter is a convenient size for on-the-go audio needs.
  • Tube Amplifier Compatibility:Supports a variety of tube amplifiers, including 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300B.
  • Durable Aluminum Body:Crafted from robust Aluminum, the adapter offers durability and a sleek design.
  • Amp Headroom|Silvester App|Versatile Impedance Support:Drives a wide range of headphones from 8ohms to 600ohms, ensuring compatibility with various models.
  • High-Power Output:Delivers a robust 8Wx2, capable of powering high-impedance headphones like HD800 with ease.
Specifications:
Body Material: Aluminum
Input Type: LINE IN (AUDIO IN)
Dimensions (WxHxD): 70X115X25mm
Built-in Battery: No
Supported Impedance Range: 8ohms-600ohms
Compatible Tube Amplifiers: 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300B
Features:
|Amp Headroom|Silvester App|Apogee Vs Universal Audio|
**Enhanced Audio Experience**
The APPJ headphone adapter is a must-have accessory for audiophiles who wish to elevate their listening experience with their tube amplifier. Designed to connect high-impedance headphones to your mini tube amplifier, this adapter ensures a seamless transition from your tube amplifier to your headphones. The robust aluminum body not only adds durability but also contributes to the sleek design, making it an attractive addition to your audio setup.
**Versatile Compatibility**
With its versatile input type, the APPJ headphone adapter supports both LINE IN (AUDIO IN) and Banana jack connections, making it compatible with a wide range of audio devices. Whether you're using a 6F3 EL84 6V6 6P3 EL34 KT66 KT88 2A3 300B tube amplifier or any other single-ended tube amplifier with similar power, this adapter ensures a perfect match. Its ability to drive headphones with impedances ranging from 8ohms to 600ohms means it can handle a variety of headsets, including the high-impedance HD800.
**Optimized Performance**
The APPJ headphone adapter is engineered to deliver optimal performance, with a maximum processing power of 8Wx2. This ensures that your headphones receive the necessary driving power to deliver the full potential of your tube amplifier. The absence of a built-in battery means that the adapter is designed for a stable connection, providing a consistent audio experience. Its compact dimensions of 70X115X25mm make it a space-saving solution for your audio setup, without compromising on performance.
