Hello all,
I've been slowly upgrading my system and I now own a Hypex NC502MP amp, KEF R11 and SVS SB-1000 sub. The final missing piece was some form of EQ/DRC I thought, to better integrate my sub and get an idea about my actual room acoustics.
Inspired by many others on this forum, I bought a MiniDSP DDRC24 and Umik-1, and started doing some measurements. The best results I get so far is when I just use Dirac and tweak the curve to my liking (no REW + MiniDSP EQ). The REW measurements actually show significant differences before and after Dirac. I'm just not completely sure what I'm looking at.
Smoothing 1/48 - Is this good or bad?
- Depending on the 'smoothing' setting in REW, it looks good or bad. Which settings should I use to determine the results is good?
- What vertical scale in the graph should I use? I have no idea how to interpret this.
- REW shows the high frequences rolled off A LOT, is this normal for the KEF R11's? Could this be a problem somewhere in the chain?
