Depends on what you want/can spendDoes someone know a good coax to spdif converter?
<$50 seems reasonable. Does more money relate to better conversion?
Topping D10 has a good usb/spdif converter, also scored pretty good in test here. A bit over your budget 89 €. IMO more money will get you in most cases better conversion.
You could also look at getting a used Fostex COP-1. I got one recently for $15.Does someone know a good coax to spdif converter?
USB is a lossless transmission with bit depth 16 , 24, 32 and sample rates up to 384 kHz in modern implementationsI’m assuming usb to digital is better quality than airplay / Bluetooth to digital - is this right?
Which chip does the digital output - USB or DAC chip?
