HarvBow07
Hello ASR, new member and first time posting. I recently found this site and am enjoying all the measurements. I have fallen prey to many of the ideologies and snake oil products that ASR tries to protect against, so thank you. I have a few issues with my current setup:
Sonos (digital) Oppo BDP105 (analog) Speaker antipode 2.0 (analog) minidsp2x4 crossover (analog) emerald physics EP100.2se x2 - emerald physics ep2.7. Speakers currently have a passive crossover for mids to highs.
When I bought the speakers and amps new, the dealer and engineer did a custom calibration and setup in my old house. They sounded wonderful except for some hiss that was and is audible from the listening position. Even though they are high efficiency speakers I would like to try to correct that. Furthermore, the work they did was saved in the minidsp 2x4. It sounds terrible in my current house and I have just lived with it for 4 years now. No matter what I need to change the eq settings. After reading a bunch on ASR I have come up with two options but they may not be the only options. I think one move forward could be removing the DSPeaker antimode and minidsp2x4 both of which seem to test poorly. At the same time I would like to remove the passive crossover and use an active one of some type. Two products that could fit the bill are the minDSP flex 8 and the Sublime Acoustic K231 analog active crossover. If I go with the flex I would get the Dirac license and try that out. The other option I see is to try to buy the miniDSP software that will let me mess around inside that unit. However because of the noise and the newer offerings I m leaning towards number one.
In a perfect world I would like it all connected with balanced cabling as I plan to buy one or more Buckeye amps. However I think in my case I could use adapter cables from the flex8 to the amps and be all right. Any problems or better solutions to consider? Also is it sound logic that replacing components with high noise and low sinad with better measuring components could help the hiss?
Sorry for length and thanks in advance,
Harvey
Harvey
