- Joined
- Jan 15, 2020
- Messages
- 6,927
- Likes
- 17,026
Interesting is also this paper on why bassreflex is often not suited for very low tunings, for example 20 Hz subwoofers
The 2 problems with acoustic port loading for very low frequencies are non-linearities and pipe resonances.Interesting is also this paper on why bassreflex is often not suited for very low tunings, for example 20 Hz subwoofers
Then we understand that whatever frequency response the subwoofer was born with does not matter, it is the output capacity that limits what can be achieved.
In all practical situations, what happens when the bass-system is placed inside a room, is what determines (small-signal) transient response. What we observe now, is a frequency response that is very different from the calculated, where now the room completely dominates.
And then add the increased output capacity due to reduced excursion to those 6dB, and it adds up to a quite significant number.At the tuning frequency, a vented box has a theoretical 6 dB advantage over a comparable-sized sealed box. Of course this is not across the bass spectrum, but it does imply that EQing the sealed box for similar low-end extension calls for significantly greater thermal and mechanical power handling for the woofer, and perhaps four times as much amplifier power, for equivalent output capacity down to the vented box's tuning frequency. My observation has been that high-power compact equalized sealed subs are more likely to have something fail than are comparable-output-capacity vented box subs because of all that additional heat.
Wow! This is beefy (as Holland's frikandel is, though, couldn't resist, appologies ... ). It's irrelevant, as far as I didn't read it. You would otherwise notice, no Thiele/Small parameters, no alignment ... and the electromagnetic drive of the driver from a constant voltage source is dealt with as a special case? He states that that would (we know: by Qe exactly) introduce "some damping". Really?Interesting is also this paper on why bassreflex is often not suited for very low tunings, for example 20 Hz subwoofers
100% nailed!
the high pass obviously creates a bump on the waterfall ... adobt a triangular shape. also the tail starts steep and ... clearly a resonance at play.
You mean the tail at 140Hz of the Acoustic Energy AE2 here? This not a port issue, at any rate not directly related to being ported. It's a different ill-effect hard to nail down without hands-on inspection what's going on here. Same for the HHb Circle 5A, also at ~140Hz. Something is resonating mechanically I'd guess.the high pass obviously creates a bump on the waterfall since the group delay isn't compensated (it's not an artifact). but the waterfalls of the ported speakers show more than that; clearly visable as they adobt a triangular shape. also the tail starts steep and gets flatter over time. clearly a resonance at play.
I would love to see those plots in the spectogram view as it clealy shows what is delay, and what is ringing.
also my example comparing similar roll-offs ported and sealed was totaly ignored
here we can see the resonance continue after the easiely identifed HP delay
others are almost as obvious, others less
still late at night was obviously far above its self-noise. I think it is mostly from traffic
Wouldn't it be nice to stop worrying?
EDIT: Could be a measurment problem as well, something gets excited to resonate, speaker stand, mic stand, whatever (I note this all was done in anechoic chamber by Studio Sound Magazine but no info given how exactly). The 140Hz tail is often there to varying degrees which is suspicous.
The interaction between the two resonances results in a system that possesses less damping and increased time delay
I have read through it too, but his reasoning for can't tune port to very low frequency is only because the mass needs to increase and stiffness needs to decrease. I think maybe he does not want subs too be too big, but not everyone is bothered by that.Sorry for revitalizing this again. I wish to turn it into positive.
Regarding the paper (https://www.grimmaudio.com/wp-content/uploads/RMS-white-paper-3-Bass-reflex.pdf), seen in its context, it is just a part of a series. From this it can be understood, why the reference to Thiele/Small is missing (yes, I read it all):
Eventually the author admits, that his efforts didn't yield sufficient outcome. Kudos for that honorable statement. Again kudos! Thank You.
But how this singled out "white paper" made it onto the Grimm Audio website, I won't comment.
