Simple learning one for 5 bucks... It has greater strenght than original, but it's not ideal either...Has anyone else use a different remote?
I suppose there is an easy way to additionally increase the power of such a remote control. The remote control has an IR diode emitting infrared light, invisible to the eye. However, despite the fact that it is invisible, there is some objective "brightness" of such a diode, which is crucial for the DAC's receiver. Therefore, the power of the diode in the remote control should be increased (current flowing through IR LED), most likely by reducing the series resistor connected to the diode (current limiting resistor). Maybe the remote control will run on batteries for a shorter time, but it will work much better... I'll try it with that cheap learning remote to father improove it's performance. Unless it turns out that the IR LED is connected without a resistor, but as far as I know, LED's are always connected via a resistor...Has anyone else use a different remote?
This is what I (have to) do in order to use a lot of my devices (consistently without issues and not just Topping) with my Harmony Hub and iTach. There are all kinds of wired and wireless IR extenders and blasters you can get too. I use a wireless one to send signals across the room to a couple of IR devices. I use wired extenders with almost all of my other IR devices to ensure commands aren't missed.You should try an IR extender to intercede between the Topping's IR remote and IR receiver.
Hey @amirm I'd like to know if the performance of the Topping A90 Discrete for preamp use is the same as the performance of the PRE90's? If I already own the A90 Discrete, would it make sense to buy the PRE90 or not? Also, would the sound quality be different?
Amirm, I don't see anything in this thread about AES48, the balanced line standard. It appears that its not supported. There's nothing in your tests that suggest one way or the other, so I thought I'd ask.This is a review and detailed measurements of the Topping Pre90 balanced and unbalanced preamplifier. It was kindly sent to me by the company. The base preamplifier with ability to switch between RCA and XLR inputs costs US $599. There is an extension that gives you four (4) more inputs (three balanced and one unbalanced) for another $250.
Splitting the functionality into two boxes is rather unique:
Unfortunately there is no immediately switch to select an input. You have to cycle through them using the "SEL" button on the left.
Remote control is provided for volume which in turn mandated relay based stepped attenuator which is quite a "high-end" feature. For any kind of home system use remote is mandatory in my book so it is great to see it implemented here. There are other cool features like setting a pre-input gain or maximum safe playback level.
The back panel shows the unusual configuration with the umbilical cord connecting the two:
As you see mains power supply is built-into it as it should in this price category.
Overall fit and finish is very good.
For my testing I exclusively focused on XLR input and output.
Topping Pre90 Measurements
As usual I setup preamplifiers for "unity gain" meaning what voltage I put in, is what comes out. On Pre90 that meant setting the volume to -6 dB instead of zero. That gives us this eye popping output:
Distortion is whopping -25 dB lower than best case threshold of hearing. Combined noise+distortion as represented by SINAD is 5 dB better than said threshold. And this includes the noise from my analyzer. Likely the actual performance is fair bit better.
Suspecting some of the good noise figure comes at the expense of lower than normal input impedance, I jacked up the default 40 ohm output impedance of my Audio Precision analyzer to 200 ohm. The result was that the output from the Pre90 dropped down to 3.6 volts (instead of 4). One click on the volume control compensated for that nicely and give me the same good performance just as well:
So there is really no penalty to the lower input impedance.
I wanted to test the effect of the external box so I selected one of its inputs and ran the dashboard again (with 40 ohm impedance);
As you see the external input works just as excellently as the internal input.
EDIT: here is the RCA performance:
Signal to noise ratio (combined with my analyzer input) is 21 bits and rises to almost 22 bits with full volume:
Note that Topping advertises much higher numbers. They do that by using a noise amplifier, measuring the results with AP, and then dividing the output by the gain of the noise amplifier. By doing so the remove the effect of Audio Precision analyzer's self noise and get much higher SNR. That is customary in chip industry. For us to keep things consistent we will continue to test as we have as any performance above what I am showing is academic anyway.
Note that the Pre90 can go up to +10 dB gain. Doing so though has a penalty in overall noise. To show the effect of output level/gain, here is a sweep:
As you see you can get to 8 volts while maintaining the full performance of the preamp. There is more gain left if you want to drive an amplifier like Benchmark AHB2 in low gain or Purifi without its input buffer.
Frequency response is almost flat to 80 kHz:
There is a bit more droop in my measurements vs Topping. Not sure why but it is immaterial.
Crosstalk was more than good enough for what we need but shy of the best that can be done:
Intermodulation distortion test is as good as the best I have tested, the Benchmark HPA4:
Same is the case for SINAD vs frequency:
Seems like the revolution we have had in high performance headphone amplifiers has bled into preamplifiers. I love it because I have a Reel Reel tape deck that I like to use occasionally in my system along with my usual DAC. Sadly hardly any premplifier could keep up with said DAC so I was degrading the performance of it to have the ability to play another analog source. With the Pre90, that compromise is no more. It is an instrument grade, more transparent than transparent, preamplifier. Other than Benchmark HPA4, I don't think it has an equal no matter how much money you spend. In that regard, it is quite a value as well although obviously not "cheap" as compared to desktop products.
It is my pleasure to strongly recommend the Topping Pre90. If you needed to have another source beside your DAC to play in your system, you now have a wonderful way to accomplish that with zero impact on performance.
It would not make any sense to buy the PRE90. Opinion as to the difference in SQ varies.Hey @amirm I'd like to know if the performance of the Topping A90 Discrete for preamp use is the same as the performance of the PRE90's? If I already own the A90 Discrete, would it make sense to buy the PRE90 or not? Also, would the sound quality be different?
One thing you'll definitely notice about good measuring equipment is you'll stop thinking if this is the best I can get. There's nothing left to go get with the upper end Topping for performance.Hope everyone is having a wonderful Sunday (or whenever it is that you are reading this). I'm thinking about putting together a Topping stack, currently running a Denon DRA-800H which i like fine but measures poorly. I want to see what all this good measuring equipment is all about.![]()
I've noticed this reading here and on reddit. With Topping (or RME or other well measuring equipment) it seems most people have been running them for years. The cure for upgradeitis.One thing you'll definitely notice about good measuring equipment is you'll stop thinking if this is the best I can get. There's nothing left to go get with the upper end Topping for performance.
I don't use headphones. Hence, my Topping stack is the Pre90; D90Se, and Ext90. I can confirm that this is it for my choices of amplification. I'm sure that any choice that you make will satisfy.Hope everyone is having a wonderful Sunday (or whenever it is that you are reading this). I'm thinking about putting together a Topping stack, currently running a Denon DRA-800H which i like fine but measures poorly. I want to see what all this good measuring equipment is all about.
My one question for y'all is regarding bass management. The DRA-800H doesn't even have an HPF for the speakers. For the Topping stack i figured i could add a MiniDSP 2x4 HD to the chain, Pre90 > MiniDSP 2x4HD > output 1 to subwoofer / output 2 to power amp then let the MiniDSP handle the crossovers. Any issues with that? I'd also be able to play around with Dirac which I've never done before.
Associated equipment FWIW is Kef LS50 Meta and SVS Micro 3000. I'd build the Topping stack over time, likely starting with the Pre90 + LA90. Just use the DAC inside the Wiim Mini until I buy a Topping DAC. Additionally I have an Oppo BDP 95 as a disc spinner and a Technics SL1200Mk2 + Ortofon 2M black for vinyl. Currently using the phono input of the DRA-800H, so I'd have to pickup a phono preamp somewhere as well. I listen via streaming (Tidal/Spotify) about 80% of the time so not super concerned being without vinyl for a bit.
Not necessarily looking for the absolute most cost effective option, part of the appeal here is the cosmetic satisfaction of having a matching stack. Also not expecting some world-changing dramatic difference in sound, though having proper sub/speaker HPF/LPF and dirac will no doubt offer improvements.
Thank you all for your time and all you do here.
