Topping L30 II Review (Headphone Amp)
Rate this headphone amplifier:
    Votes: 10 2.7%
    Votes: 11 3.0%
  • 3. Fine (happy panther
    Votes: 30 8.2%
    Votes: 315 86.1%
Cuprajake
Brilliant,
I'm getting rid of my ifi stack as its popping from DSD switching.
What's the best way to run the topping stack to avoid this. I use Deezer via my phone for audio
Into a set of LCD-2
I literally have a wireless mouse in front of the l30 and have 0 interference. Maybe it's the DAC instead and the l30 was just amplifying it?
it's strange. do you have a very long headphone cable? I am using a 3m cable for my Oppo PM3. When I call with my phone and hold it to the headphone cable it picks it up. But also just holding the phone on top the amp it picks it up. Very strange.
I just need to keep stuff away from it. The whole unit is so perfect otherwise that I will just have to life with this fault. I wish they would release the L30 ii but as balanced version with the same controls as they are freaking perfect.
Cuprajake
So here we are
So far so good, powered off my old lg g7 charger
Sounds really good so far, using wavelet auto eq got loads of power
I may stack them, best to put the amp ontop?
Maurito
Has anyone measured the Topping L30ii channel crosstalk? On the Russian forum, the result was -74db, which does not correspond to the declared -92db. Please measure. I am considering buying.
solderdude
The Neitherlands
Consider that even if it were -74 dB this already is waaaaaayyyyy better than needed. A channel separation of -40dB is already sufficient. I would not let such an unimportant spec determine a purchase decision.
try with a load of 32 ohms
Most likely any 3-wire headphone cable (combined with low imp. headphone) is far worse than that, and does so in the opposite effect as actual crosstalk.
Maurito
Thanks for the quick replies. Because in the L30 of the first version with a load of 32, everything was fine. And in the L30ii, the characteristics are already more modest. Great product, I will buy. I clarify out of curiosity, as there may be a reduction in quality or other reasons.
solderdude
The Neitherlands
Yes, just like the original L30 except the high gain (fortunately) is higher in the L30-II version.
There basically are 2 gains. Mid and High. The low gain is simply mid gain with an attenuator in front of the amp.
All settings are waaaaayyyyy better than is needed so simply use the gain that is needed.
The max. output voltage is also even higher so better suited to drive high impedance headphones (and why it needs a higher gain).
The L30-II can actually be driven to its max output voltage when driven from a 2V source, the L30 could not.
Yes, just like the original L30.
thanks. so basicly the attenuator causes slight distortion (on paper) right?
solderdude
The Neitherlands
It just lowers the S/N ratio. We are just 'looking' at the noise floor instead of distortion.
solderdude
The Neitherlands
You are looking at the noise floor of the AP555x. If Amir were to do a loopback it would give the same 'results'.
see Amirs remark on the right bottom of the FFT:
When the signal level is lowered the noise floor of the AP is determining the plot (and thus seems to have higher distortion as it is noise + distortion). The L30-II is actually better than the AP.
SmokedBurger
at the moment I have a 2-meter cable plugged into my Philips Fidelio X1s which is my shortest cable. On my other headphones I also hear nothing though they have around 3-5 meters in length.
When you do a mobile call (not over telegram/whatsapp) and hold the phone right at the L30 ii you hear no interference?
