Some explanation from ESS about digital vs analog volume.I have discovered an old whitepaper from Wolfson.
There you can read that actually a reduction of the resolution (lower SNR), is generated by quantization errors.
While the SNR remains constant with an analog volume control.
However I ask myself, in how far one with the Neutron player, which works internally with 64 bits, I dither activated, and the signal with 32 bits, and 384 kHz to the converter sends...
In addition, there is probably a publication in, Zwicker: Psychoacoustics,
Although according to the ear is not able to notice the lower resolution because the signal also becomes quieter.
Well, listening quietly is nothing for me anyway...
I just wonder then why Amir measured only 100 dB dynamic range at the output of 50mV?
And an explanation from John Yang why the L30 II measured worse at low gain than mid gain in Amir measurement.
