- Joined
- Oct 25, 2019
- Messages
- 11,119
- Likes
- 14,788
Just a quick question guys:
Right now I'm using E30 in preamp mode with a netbook and a power amp. I'm planning to buy L30. If I plug it between E30 and my power amp, will I still be able to use the volume control of E30 when using my power amp? YES But I would experiment and find the loudest L30 pre amp setting you would want coming through your speakers with the E30 at nearly full volume- remember that gain and dial position (or mark it on the device) then use the E30 remote to fine tune the volume during listening at your convenience.
And also does the L30 volume knob work only for headphones or for preamp mode as well? BOTH- there is a switch but the vol knob applies to both- see comments above and apply same logic to headphone listening.
see comments by each ?
