Newcomer here, but long time forum reader, so please pardon me...
I have an E50, recently purchased based primarily per Amir's
superb reviews (I am a big fan), and
love it other than one glaring flaw.
I have contacted Topping regarding it in great detail but suspect that they may already have grown tired of hearing from me.
Please allow me to describe the problem here to see if anyone else has had the same issue.
I am driving the E50 from a Raspberry Pi4B and MoOde streaming setup.
All software and firmware including MoOde, ALSA, MPD and the E50 itself are the latest/current versions.
The E50 is powered by the same heavily filtered 5V supply as the Pi, and it powers on and off with the Pi simultaneously, and with the system as a whole via a master power hub.
Its outputs feed into a Marantz amp using the single-ended DAC outputs and then on to speakers or headphones as needed.
In
A-O setup mode (timeout timer active, auto power on) the unit will power up into an inert state ("off") and during the MoOde boot process it will turn on as expected.
However, if I then search for something to play for more than 60 elapsed seconds, the DAC powers itself off.
When attempting to play anything it then takes at least two or sometimes three tries (with error messages popping up) to get it to do anything.
Or to touch the front panel button on the E50 to "wake it up" before play.
And about half the time the MoOde setup reverts to the Pi audio jack when the E50 goes to sleep because the E50 is no longer enumerated in the available options list.
So far, this
may be perfectly normal behavior in the "auto power on, auto timeout mode".
I get that.
Topping suggested I try the
A-C setup mode (continuous operation, no timeout timer).
Fair enough, but it does not actually resolve the problem, as I have explained to them in detail.
The issue is that in "continuous" mode it
still powers up on an inert state.
In other words, it will
not power on to an active state regardless of what other options are configured in the E50, and certainly not with streaming output.
This is not exactly what one would expect from a "continuous" configuration and it makes no sense at all (to me anyway).
This requires the remote control to be used, or to touch the front panel button, to turn the DAC on every time power is cycled.
If this is not done before the MoOde software completes its booting the E50 will not be recognized or listed as an available output option.
FWIW, I also tried this with Volumio with the same results, so it is not just MoOde being weird.
Nothing in the streamer software settings works around this issue other than "play upon power up", and the
A-O mode, which is a somewhat cheesy solution IMHO.
If this were installed into an A/V rack in a closet somewhere it would be a complete and total PITA to deal with.
I also tried connecting a
far cheaper DAC/headphone amp to it (which uses a PCM2706 USB interface and ES9023 DAC chip).
It
always powers up as "on",
never times out, and works every time it is asked to with no issues whatsoever.
This happens regardless of elapsed idle intervals or power up sequences.
So it is definitely an issue within the E50 itself.
My questions are-
Is anyone else seeing this issue or do I have a defective E50?
Does Topping's very brief 60 second idle timeout seem reasonable to anyone? I think it should be more like 10 minutes,
if at all.
Why is the timeout and auto power down needed for such a low power device anyway? What's the point?
Is there some reason that I am not grasping why such an otherwise excellent device should power up "
off" (particularly when
continuous mode has been selected)?
Makes absolutely no sense to me, and so far there are no working suggestions from Topping.
The solution seems very simple- in
A-C mode, power up "ready and active" and
stay that way.
In my mind this is a firmware bug.
Sorry for the novella, I just wanted to present the entire situation for your consideration.
Thanks.
