When both are expected to be SINAD 120+, what is left to wonder are features and price.The E70 and L70, which are the upper models of the E50 and L50, are introduced.
The release date is October 25th. I'm curious what the content is.
The width of the cases of the E70 and L70 has increased considerably, so they probably have a built-in power supply.When both are expected to be SINAD 120+, what is left to wonder are features and price.
I had high hopes for the PA7 due to the PA5 situation.PA7 incoming?
If it were to be, my guess would be Q1-2 of 2023.I had high hopes for the PA7 due to the PA5 situation.
It is not in the lineup this time, but it may appear after this.
The E70 makes good use of the old ES9028pro to improve performance and reduce costs.
TOPPING E70 ES9028Pro Digital to Analog Convertor (DAC)
Features: Super audio reproduction ability with ultra low distortion The E70 uses ESS SABRE flagship DAC ES9028PRO. ES9028PRO has a 32-bit 8-channel HyperStream II architecture. In the application of E70, every 4 channels are connected in parallel as one channel,achieving high performance and...shenzhenaudio.com
Who needs improved performance? No new features to speak of. Not interested.The E70 makes good use of the old ES9028pro to improve performance and reduce costs.
Magic is what it needs to hear the improvement (which is admirable) or to see new features.The E70 seems to make good use of the old ES9028pro to improve performance and reduce costs at the same time.
If this spec is true, what kind of magic did Topping use again?
There is 12V trigger, for some users this is very important.Who needs improved performance? No new features to speak of. Not interested.
What does the MHz reading of the screen refer to?l7audiolab measurements out of the new series.
https://www.l7audiolab.com/f/topping-e70/
https://www.l7audiolab.com/f/topping-l70/
Sample rate.What does the MHz reading of the screen refer to?
Import enough to upgrade their current DAC? That would be an expensive 12V trigger.There is 12V trigger, for some users this is very important.
Damn! No FM radio thenSample rate.
DAB+ would have been interesting.Damn! No FM radio then
Google Translate "I am using L30 ii to combine with hd600 headphones. I decided between the e50 and the d30 pro, as the d30 pro is a bit over my budget, but if the d30 pro is really different, I can afford it. I just need a good feature and no additional features! one more thing, with 5v input source can i use my pc's usb 3.0 port, cause that would be much more convenient, is there something wrong with this? Thank you and sorry for my poor english!"Tôi đang sử dụng L30 ii để kết hợp với tai nghe hd600. Tôi quyết định giữa e50 và d30 pro, vì d30 pro hơi quá ngân sách của tôi, nhưng nếu d30 pro thực sự khác biệt, tôi có thể mua được. tôi chỉ cần một tính năng tốt và không có bổ sung các tính năng khác!
một điều nữa, với nguồn đầu vào 5v, tôi có thể sử dụng cổng usb 3.0 của máy tính của tôi không, vì điều đó sẽ thuận tiện hơn nhiều, có lỗi gì với cái này không?
Cảm ơn bạn và xin lỗi vì tiếng anh kém của tôi!
thanks i fixed it! what about d30 pro?Google Dịch " Tôi đang sử dụng L30 ii để kết hợp với tai nghe hd600. Tôi đã quyết định giữa e50 và d30 pro, vì d30 pro hơi vượt quá ngân sách của tôi, nhưng nếu d30 pro thực sự khác biệt, tôi có thể mua được. Tôi chỉ cần một tính năng tốt và không cần tính năng bổ sung! một điều nữa, với nguồn đầu vào 5v, tôi có thể sử dụng cổng usb 3.0 của máy tính của tôi không, vì điều đó sẽ thuận tiện hơn nhiều, có gì sai với điều này không? Cảm ơn bạn và xin lỗi vì tiếng anh kém của tôi ! "
E50 không cần nguồn điện riêng biệt với USB cho âm thanh. Nó sẽ hoạt động khi sử dụng 2 cổng USB từ máy tính, một để cấp nguồn và một để truyền tín hiệu âm thanh kỹ thuật số.
