Topping DX3 Pro+ USB connection to mobile phone
Favalessa
Hi everybody,
Sorry if this has been asked already, I couldn't find the answer searching in the forum.
How do I connect my mobile (iPhone with USB-C port) to the Topping DX3 Pro+?
Can I just use a USB-C to USB-B cable directly, without using the USB-A to USB-B cable provided with the unit?
Thanks in advance!
On Android you can, I'm using it right now (in combination with UAPP for best result/SQ) Not sure about iPhone as I don't have an iPhone... wouldn't surprise me if it doesn't work.
Can always use BT, which works for sure.
Hello, it's my first post in the forum.
I can confirm that on iPhone and with the lighting to usb dongle from Apple you can use a regular usb-a to usb-b cable and play music from your iPhone through the USB input of your Topping DX3+ Pro. I am using this everyday to play lossless audio from my iPhone into my headphones.
So in your case is even easier and with a usb-c to usb-b it should work.
