Hummingbee
- Joined
- Jul 21, 2024
- Messages
- 3
- Likes
- 5
I purchased the Topping DX3 Pro+ a couple of days ago to use with my JBL 305 speakers and HD600 headphones. On the first day, I had a great experience with it connected to my PC. I made sure to install the correct Topping audio driver, and everything worked well for hours.
Two days later, I powered on my PC and noticed there was no sound whatsoever. The audio driver software indicated that the device was connected and working, and Windows showed no issues and even displayed audio being played. I did the first thing I could think of and Googled the issue, finding a forum post suggesting disconnecting the power for a few minutes due to "protection mode" (though I couldn't find any information on this online). This didn't work, so I tried a factory reset, but still no sound.
I was about to start the return process with Amazon when I thought of trying a firmware update. I downloaded the correct firmware and started the process, but after one minute, I got an error with the upgrade: "TUSBAUDIO_GetDfuStatus: Function failed with error code 0xEE000003."
I restarted my PC and attempted the update again but received the same error. After some more Googling, I found information unrelated to Topping regarding USB ports. I moved the Topping device from a USB 3.0 port to a USB 2.0 port and attempted the firmware update again. This time, it completed successfully, and the audio started working again. I'm not sure if it was due to the USB port change or the firmware update.
I made this post to provide information in the hope that anyone searching for the same error code can see it and first try changing USB ports.
