Veri
- Joined
- Feb 6, 2018
- Messages
- 9,647
- Likes
- 12,187
This tiny thing has a direct DSD mode, then?I can recommend the Direct DSD mode with HQPlayer feeding the DAC.
I use the free version, runs 30 minutes with the same features as premium. Pretty nice!If HQPlayer were free then sure, but it costs $360.
Ah I meant the mode transporting DSD directly, without DoPThis tiny thing has a direct DSD mode, then?
Native DSDAh I meant the mode transporting DSD directly, without DoP
Only if A: your phone can supply enough current via its USB portWhat if I wanted to connect it to an Android phone that's USB type-C ?
Would it work with merely an adapter ?![]()
According to measurements by L7Audiolab and Reference Audio Analyzer, the Topping DX1 should be able to drive the Edition XS to almost 117dB SPL Peak.Would the DX1 supply enough power for the Hifiman Edition XS?
UAPP if you streaming tidal or QobuzHi everybody. I wonder if this little beast could be used directly with a smartphone. It would be less portable than a Topping G5, but also three times less expensive
Granted it would also drain the smartphone faster since it doesn't have its own battery, but it shouldn't be a big problem if the smartphone has a big battery. If you know a better solution for 99 €/$, just let me know.
The intended use here wouldn't be "walking / inside a pocket" like the G5. It would rather be "sunbathing on a garden / terrace". So just relaxing in a deckchair, with the smartphone and the DX1 sitting close on a coffee table. Would that work? Would the DX1 be recognized by the smartphone (possibly a Redmi Note 9 Pro), with no need for drivers and such?
Bonus question : which Android EQ app would be best for applying some Oratory presets to the few headphones we have? It would have to work with Spotify, since all the music will come from there.
Thanks!
And what if you use that for connecting the dx1...it's just an adapter you can the. connect the dx1 to the phone it's just a data transferQuick question: the provided cable seems to be USB type-A.
Why it wouldn't work?Would it work with merely an adapter ?
Handily, Crinacle.com comparison tool will allow you to input your PEQ filters (doesnt matter which HP/ IEM model you apply it to on the site) then you can export it as GEQ for Wavelet and then import that into the autoeq function on wavelet (handy if you have a Google Drive linked to your phone and laptop so you can export to drive and import on Wavelet directly from the same Drive folder.Wavelet and Poweramp EQ are your only options afaik.
Wavelet is easy to use as you can load all AutoEQ presets with a single tap.
Disadvantage is that AutoEQ uses a different target with less bass (Not stock Harman) and the filter parameters are computer generated.
Poweramp EQ on the other hand gives you the option to apply the preset from oratory's PDFs one to one, but it's a bit tedious to enter everything by hand.
Btw @Jimbob54 I wanna use the cross feed feature for enjoying old record more but I don't understand how it work with the dB and the freq could u make a little world-class in thy regardHandily, Crinacle.com comparison tool will allow you to input your PEQ filters (doesnt matter which HP/ IEM model you apply it to on the site) then you can export it as GEQ for Wavelet and then import that into the autoeq function on wavelet (handy if you have a Google Drive linked to your phone and laptop so you can export to drive and import on Wavelet directly from the same Drive folder.
Now if only they would add crossfeed to Wavelet I could almost live without UAPP (and not be tied to Tidal/ Qobuz)
On UAPP? Try 9.5dB, 650Hz. I think that approximates the Jan Meier type filter. I suspect @staticV3 or @maverickronin might be able to tell me how wrong I am thereBtw @Jimbob54 I wanna use the cross feed feature for enjoying old record more but I don't understand how it work with tv dB and the freq could u make a little world-class in thy regard?
Theres only the 2 sliders so knock yourself out adjusting both to tasteOk good going to try that
Thanks
xD yeahhhhhTheres only the 2 sliders so knock yourself out adjusting both to taste
