Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Thanks for all the support much appreciated. I had no idea that foobar had a matrix mixer plugin, that's super valuable. I use both but foobar is so much slimmer of an app I'd like to go back to leveraging it more.
No media player is perfect so I go between these two and a couple others. Adobe Audition also has channel mapping but it isn't a media player. Also, you can use jRiver audio output in Kodi, and take advantage of the mapping. I use jRiver and Foobar the most.
I just checked mine and I run at 8192 in safe mode. I regularly run 5.1 in native DSD128, without issue, in J. River. That being said, I have 64G of DDR4 ram in a mid level AMD Ryzan. As for video, nothing I've ever seen is better the the DM7 for movies\tv in surround.
Honestly, in any ASIO I've run this setting has never really affected the performance of whatever DAC I've had.
Dartin Bout, thanks for shortening your signature. Some people use a "spoiler" button on this site.
VOLUME CONTROL on the DM7 is not good.
I think the main weakness of the DM7 is the remote control volume control, if you use that volume control, it either changes the volume too slow or too fast. I constantly use its volume control so it matters a lot to me. My Topping preamp has the same problem.
Still, based on what is on the market today, I would buy the DM7 again today. I hope they do a firmware upgrade to somehow give a medium speed.
Dartin Bout,
What is the purpose of listing all your equipment on separate lines on every post? So much scrolling and screen space taken.
There is a "spoiler" button some people are using here, to show their equipment list. I am such an a-hole, I don't even like that button creating a distraction from the thread. Seems like the 2 line signatures are less distracting than the button. But if a long list is important, the botton is good.
I've been running the DM7, for a few hours (6-8), daily, since July 22. I had the Okto DAC8pro before. Both produce significant pops upon power cycle. I learned to turn off the SW and the 2 amps 1st, then the DM7. Other then that nothing. Are you running these straight from TRS to XLR? Do you have another XLR dac to test with your amp? If you're running the TRS into RCA connectors, this is considered a "corporal sin" in these pages.
I leave the DM7 on 24x7. Only difference is the PC sleeps from 0100-0600am.
I can only suspect a couple of possibilities:
- running very high sample rate therefore playback is more sensitive to pc load
- sudden network traffic causing dropouts
After dropping the firmware to 1.17, so far so good. Will continue to monitor.
I am using a DM7 and do not get any sort of pops at all, however, while I turn off amps and put the computer to sleep or turn it off, I never turn it off the DM7. You might considering trying that since it doesn't consume much power. Also, when doing a sequenced shutdown with amps turned off first, turn off anything upstream no earlier than 30 seconds later.
Question about the 3 "Auto" power modes, signal, trigger and off.
When I select the "auto trigger" setting it works as expected, however "auto signal" is also enabled and each time the computer wakes the DAC comes out of stand-by.
Is there a way to stop this behavior?
Thanks for all the support much appreciated. I had no idea that foobar had a matrix mixer plugin, that's super valuable. I use both but foobar is so much slimmer of an app I'd like to go back to leveraging it more. No media player is perfect so I go between these two and a couple others...
www.audiosciencereview.com
I'm especially concerned-more like scared of hearing damage (!)-since from prior discussions you surmised that my speakers are likely 6db more sensitive than yours-and my room is less than 2900 cu ft.
If you did not get these transients why do you suppose dartinbout does? But if you did get these thumps was this among the reasons for moving to the Hapi, or did you find one or more solutions to prevent them?
