Not that I think the differences are audible but just wanted to point out there are trade-offs among filter length (delay), ripple, steepness and attenuation. Also, if one wants to use software upsampling anyway it can be done for free using something like the SoX plugin for foobar2000. Even MPC-HC can do some implicit auto upsampling with the built-in (libsamplerate?) resampler with more than decent results.
If my answer is "yes" then I need to provide some blind test results so I would not say this. The whole thing started from someone claimed some minor imaging up to ~0.55fs is wrong and driven by marketing:Is the filter ripple bad and affects sound quality?
Maybe. It's certainly higher than any of the examples given by Julian Dunn in his 1998 paper.Is the filter ripple bad and affects sound quality?
Interesting. What is the best USB->S/PDIF bridge?I have in the past. Not much to look at there that is significant.
You can only test it with an external dac. And we paid attention to that as well. Coax output is better than AP's. The toslink output is also good enough.
Any reason I can’t use this with a pair of RCA splitters to drive a pair of active speakers and a sub? Will the output be halved or will the opamp increase voltage? I apologize in advance if this is a dumb question, I am generally mistrustful of electrons and doubt their motives.
I'm guessing you're talking about analog output not the digital. It will probably be fine. The output voltage will stay the same, but the D10s will have to provide more current. This shouldn't be a problem unless your speakers or sub have an unusually low input impedance, say <10k Ohms.Any reason I can’t use this with a pair of RCA splitters to drive a pair of active speakers and a sub? Will the output be halved or will the opamp increase voltage? I apologize in advance if this is a dumb question, I am generally mistrustful of electrons and doubt their motives.
Yes, I meant analog out. My speakers, are KRK G4’s and the sub is an older Atlantic Tecnology with RCA input. I went ahead and tried it, everything seems to be working ok — no smoke pouring out of anything.I'm guessing you're talking about analog output not the digital. It will probably be fine. The output voltage will stay the same, but the D10s will have to provide more current. This shouldn't be a problem unless your speakers or sub have an unusually low input impedance, say <10k Ohms.
Cool, just starting to read up on the miniDSP, I think i’ve convinced myself I need one so that would be handy.I am doing this but digitally. I use the SPIDF into my Genelecs active monitors (using SPIDF AES cable) and use the toslink output to miniDSP 2x4HD DDRC24 which feeds into my 2 SVS subwoofers. Works very well.
Then I have just one more follow-up question that I honestly haven't thought about before. I have only had the option of optical out from my motherboard but the D10s would now allow for a coaxial digital connection. Any advantage or disadvantage to either type (assuming to a Geshelli Labs Enog2 Pro?) Edit: Or a link to an objective article on this topic?I don't see why it shouldn't work. Seems worth a shot.
Optical can break ground loops if you have any. Coaxical is otherwise generally better received inside the DAC because good optical receivers are expensive and not as available since COVID. Then again these low levels of jitter are proven not to be audible though (-120dB is audible threshold).Then I have just one more follow-up question that I honestly haven't thought about before. I have only had the option of optical out from my motherboard but the D10s would now allow for a coaxial digital connection. Any advantage or disadvantage to either type (assuming to a Geshelli Labs Enog2 Pro?) Edit: Or a link to an objective article on this topic?
