azzy_mazzy
- Joined
- May 31, 2020
- Messages
- 80
- Likes
- 92
will something like this fix noise coming from the GPU into the speakers when there is a load on the GPU?
We suppose it's minimum phase but only @JohnYang1997 can confirmIs the filter FIR (linear phase) or IIR (minimum phase)? I assume there aren't selectable filters.
I'd love to get this but I have a preference for linear phase filters
You would need to interface TRS to 4.4mm pentaconn. Not impossible but it would be a lot easier to source such a cable with XLR instead of TRS... so not sure how feasible it is.I have the 10s, I feel like buying 10b for the purpose connecting to ifi zen can..... dunno if possible.....
I'm well aware of the lackluster "amp". It's also got some funky controls, super expensive proprietary cables, and odd issues with the Nyquist filters.
It should.will something like this fix noise coming from the GPU into the speakers when there is a load on the GPU?
So does this product make the Schiit Modius obsolete?
Thanks for the answer. I guess that means the only relevance the Modius has left in the market is getting good SE and balanced for $200 in one package as opposed to spending $100 for SE (Liquid Spark or D10) and $140 (D10b) for balanced.I mentioned this in a comment above. A lot of people in here going nuts trying to turn this into a single ended DAC with adapters that aren't recommended by the manufacturer, when they could just get the Modius and have both connections. Adapters aren't $60 worth but they do end up making the price difference not that wide so why not just buy the product that suits that actual use case. If you don't need one output or the other then Topping has two great products for you, but if you want both just get the Modius.
And more inputs ... and being able to feed se and bal with the same signal at the same time...Thanks for the answer. I guess that means the only relevance the Modius has left in the market is getting good SE and balanced for $200 in one package as opposed to spending $100 for SE (Liquid Spark or D10) and $140 (D10b) for balanced.
Regular XLR cables since TRS-XLR adapters are provided with the DACsorry for asking, does anyone here have a picture of the balanced cable I should use for this DAC?
I wasn't able to imagine what it'd look like, or where can I buy it.
Just buy a cheap xlr 3 pin cable. i can recommend cordial cables. they look like this https://www.qwant.com/?client=ext-firefox-light-sb&q=xlr+cable+3+pin&t=images there is this unknown shop called Amazon or this marketplace eBay nobody has heard of, that's selling cables like this. But this is my secret insider tip for you.sorry for asking, does anyone here have a picture of the balanced cable I should use for this DAC?
https://www.amazon.com/gp/product/B086JX7J8K/ref=ox_sc_act_title_2?smid=AM2L6367B0WB6&psc=1sorry for asking, does anyone here have a picture of the balanced cable I should use for this DAC?
Oh, good point. Didn't think about that. I guess there's equipment out there that provides Toslink, Coaxial, and/or AES but not USB input?And more inputs
Is there an audio benefit to using both balanced and SE at the same time as opposed to just one or does it just make it easier to switch between outputs? If it's just more convenient then it seems the Modius is still a great budget DAC for people who like to switch between balanced and SE outputs.... and being able to feed se and bal with the same signal at the same time...
Neutrik TRS to XMR adaptor can be found for $12, so 24 for both. I suppose that Topping can get them for less, even at $15 for both, it leaves $124 for the DAC, so $15 more than the D10s, which if I'm not wrong has same chips but with unbalanced output instead of balanced on this D10bWow, my brain fail to register that. I would have been impressed with any TRS to XLR connector but you guys went for the gold standard, very expensive European brand on a 139$ DAC, it just seems very overkill, Heck Around here those adapters are like 20$+ a piece... I don't get it there's some magic going on in Guangzhou. To come up with these pricing...
In what cases would the adapter pose a reliability issue? I'm asking because I'm on the fence over getting TRS to XLR cables or standard XLR cablesThere should be no measurable differences. But in practical sense I prefer TRS to XLR cable since it's more reliable.
If you are to buy new cables, TRS to XLR is always recommended in this case.In what cases would the adapter pose a reliability issue? I'm asking because I'm on the fence over getting TRS to XLR cables or standard XLR cables
