Hi, when I woke up this morning I discovered my Topping A90's power indicator was blinking green (I left it powered on and set to the HPA output overnight). Switching back and forth between Pre/HPA/Off didn't change anything, so I turned the switch to the Off position and then flipped the power supply switch on the back to fully power down the unit. Waited a bit and turned the unit back on, and it appears to be functioning normally again.
I think what happened was that there was a power outage early this morning before I woke up, and that probably caused this issue. Does anyone know what that blinking green light indicates, and should I be worried at all? I couldn't find anything on it in the manual, but like I said, the unit appears to be working normally after a power cycle.
Thanks!
Thanks!
