Thread dedicated to the Topping A50S
escalibur
Thanks @JohnYang1997
I'm still expecting my L30 + D10s order so I think it's gonna be 'good enough' combo for my DT1990 Pros. :)
hmscott
About an hour ago I got the Apos announcement via email:
New Product Launched: TOPPING A50s Headphone Amp
We're thrilled to announce the all-new TOPPING A50s Headphone Amp and the TOPPING 50s Ensemble. Designed to work in perfect harmony, the A50s completes what the D50s starts, driving music through a single-ended or balanced out with astonishing transparency. (Plus, they look great stacked up.)
The TOPPING 50s Ensemble combines the A50s and D50s with the TOPPING P50 Linear Power Supply and your choice of headphone: the Dan Clark Aeon 2 or the Quad Era-1. The best part? You'll save huge amounts from what you'd normally pay for all the items individually.
As always, when you buy the products you love on Apos Audio, you not only get the original manufacturer's protections and guarantees, but you also get the Apos Audio Promise that you've come to appreciate. We're providing the Apos Extended 2-Year Warranty on all products along with 30-Day Lowest Price Guarantee and Free Returns
Nice looking '50s "Ensemble" :)
https://apos.audio/collections/apos...s-topping-50s-ensemble?variant=32494814429258
The 3 units Ensemble is currently discounted to $569.99 from $605.96
Perhaps Topping will make an external power supply driven A90 / D90 MQA + perhaps that rumored P90 "pre-amp" - hey that should have been the power supply name for the '90's stack!
In 2021, will that be the A100 / D100 / PR100 / P100 stack...? :)
Hifigo New Arrivals: https://hifigo.com/collections/new-arrival?sort_by=created-descending
Pre order TOPPING A50S Balanced Headphone Amplifier AMP Preamplifier
https://hifigo.com/collections/new-arrival/products/topping-a50s?variant=32417861074993
Amazon: Topping A50s Preamplifier NFCA Fantasy HPA for Desktop HiFi 4.4mm Balanced Output Headphone Amplifier (Silver)
https://www.amazon.com/dp/B08JP7Q3GC
zenki
What's the difference between SE & Bal. amp?
I assume bal. is better but isn't bal. need whole setup to use bal. connection?
kkeretic
Croatia
How does the preamp work when the device is turned off? Bypass as on the A50 or still volume controlled, if it works at all?
raif71
I would expect like the l30 ie volume controlled. A50s has to be turned on and not bypass like A50.
kkeretic
Croatia
If so, it's time to pick up another A50 for future use before they disappear, I see their price dropped from 169€ to ~144€ on Audiophonics.
Atanasi
The upcoming A30 Pro would use bypass, but it will be more expensive and with a different set of features.
H
Human Bass
I ordered mine, time to sell the L30.
It will be my end game (for real, i swear). I dont have anything very hard to drive but i like the mojo of a balanced out. So a small, super clean bal amp is all i need.
JohnYang1997
China
Awesome, thank you! For future reference, is there a quick way to determine if a stack would pair well with a given pair of headphones?
When I use with DT880 600Ohm. It has already enough power. T60rp is a piece of cake for L30.
Only K1000 and HE6 are pushing it (still enough for normal use). All other dynamic or planar headphones can be easily driven by L30.
Toku
Japan
The AC-15V power adapter is used for the L30, but the DC-15V power adapter is used for the A50s.
Why does Topping make such a choice?
JohnYang1997
China
Because A50 was using DC input and there's already P50. Internally A50 and A50s are using SMPS, if it's linear like L30 it would require larger chassis for capacitors. And it will run even hotter. Remember A50 and A50s are balanced amp.
These three reasons made A50s still 15V DC input.
Toku
Japan
Thank you for the commentary. I was able to convince.
Mr:River
What gain do you get when using P50 + DX3pro?
I found no opinion on.
