Yes, they are always confused with overdriven guitar amps.Tube amplifiers do not need to be distortion generators; many are but some are not.
Yes, tubes have great sound. I have the Fx-Audio Tube-03 pre-amplifier. Using with a well-measuring solid-state amp. Great sound and low distortion at the same time.I built 2 pair, one large, one smaller, of home brew circlotron-style power amp mono-blocks (130wpc, 70wpc) that have low distortion. Loop and inter-stage feedback is used to clean things up a bit.
Exactly!Depending on what he means by "returns the music", unless he's heard the master on the equipment it was completed with he doesn't have a frame of reference to judge. What we know is that the signal coming out of a tube Amp is not an accurate representation of what went in so at best it means he likes the distortion tubes provide.
One must not contradict the genius friend. Semper Ubi Sub Ubi.
Alas, this is really, really old ground at ASR.
I have a friend that I consider a genius in building/modifying Hi-fi electronics.
He has made solid state amps that measure flat AND tube amps that do not…
His comment is that no matter the measurements, the tubes return the music.
I attribute this to the second harmonics… “de gustibus non disputandum est!”
Very Cool, that is a very interesting output stage topology especially the simplified output transformer requirements.I built 2 pair, one large, one smaller, of home brew circlotron-style power amp mono-blocks (130wpc, 70wpc) that have low distortion. Loop and inter-stage feedback is used to clean things up a bit.
Sorry but adding distortions to the source would not be a genius path to a High Fidelity result.He has made solid state amps that measure flat AND tube amps that do not…
This is tiresome.I'm gonna guess genius friend is also a vinylphile. Also gonna guess genius friend has never done a blind comparison.
This is tiresome.
His genius friend likes tube and vinyl sound. So what? Stop whining about that.
Anyway Amir said you need to be trained for a successful blind test. Not everybody has the time and energy for that.
This is tiresome.
I have a pet theory that certain types of amplifier induced distortion mimics the sort of distortion you get at a live venue
I have a pet theory that certain types of amplifier induced distortion mimics the sort of distortion you get at a live venue. Basically, I think it's a psychoacoustic effect. I would need to quantify the sorts of distortion that live venues cause to know if there's anything to it, but I don't really care enough.
@Phos,
While the situation got better over the last two decades, when I recall my early concert live sound experiences in the 70ies, often from basically broken PA setups in small/medium venues (bad amps being fed with misaligned crossover signals from a so-so mix into mediocre horn systems, all setup often by less experienced people)... well, I sure don't want any amp to recreate this sound, haha!
Only really big shows sometimes had phenomenal live sound, on of my personal highlights was a Peter Gabriel show in the 80ies.
