We should probably have a queue of people that will jump down other people's throats for saying something silly. It will save time and repetition
I dunno. A lot of my experience with rock music in my youth was with bands trying to out-muscle each other on stage using the likes of Phase Linear amps driving A7 cabinets. I expect there was plenty of distortion happening then, or at least plenty of clipping.Distortion doesn't mimic venue acoustics, echo, reverb, time delays
DSP can mimic that.
I am not sure, I was in live sound in the 70's and on and off since and am in large scale sound now..I dunno. A lot of my experience with rock music in my youth was with bands trying to out-muscle each other on stage using the likes of Phase Linear amps driving A7 cabinets. I expect there was plenty of distortion happening then, or at least plenty of clipping.
Music listening for me as an older adult has been mostly unamplified. For that, I have only the distortion of my aging ears--amps can't help that.
Rick "KSTR got there first" Denney
Well, a properly designed array should not do that. Array design is not actually that incredibly hard. How to make constant-beamwidth arrays with a particular apparent point of origin is now pretty much old hat.Logically too as a single musical sound event should not arrive spread out in time according to the distances to each source
Gentlemen:This is tiresome.
His genius friend likes tube and vinyl sound. So what? Stop whining about that.
Anyway Amir said you need to be trained for a successful blind test. Not everybody has the time and energy for that.
This is tiresome.
Gentlemen:
This thread is titled “Things that cannot be measured“, so I tossed in an anecdotal report. I point out my signature and my response to the “one man’s opinion “—- “Exactly!”
As to vinyl, he has not owned a turntable in a decade, rather all CD and Tidal streaming. He simply does not like vinyl.
Subjective opinions are just that; I subscribe to this site for the objective view. I try to understand why some object to measurement based evaluation. My friend‘s opinion on my Benchmark preamp and bridged amplifiers reflects his thoughts on tubes vs solid state- obviously we do not agree. I do not debate religion, politics or others intimate preferences; I will continue to post opinion statements on “Hi-fi” reproduction.
Tillman
Hi JJWell, a properly designed array should not do that. Array design is not actually that incredibly hard. How to make constant-beamwidth arrays with a particular apparent point of origin is now pretty much old hat.
Actually, Tom, there are solutions that provide an appropriate impulse response over a wide area. This is not the usual arrangement for high-power arrays, because it impacts power handling, but the solutions exist, and have in fact been implemented in low-power arrays very nicely. Doing this in a high-power array is not actually that difficult, but the array structure is most certainly not a uniformly spaced array.Hi JJ
I suppose the issue is how one is looking / what one is looking at. I have not measured a CBT but i have heard them and made a synergy horn which has similar dispersion behavior but doesn't radiate as individual sources or incur the excess hf loss or what ever it was called in Don's papers..
With the concert system based arrays used in large rooms, ball fields and sports stadiums etc, one could adjust each element to the nth, so that what arrives at your microphone and in at least one ear is from all the sources in each box in sync and your impulse response and phase looks like one arrival, like a single driver.
The issue is, because each source has an individual path length to the mic or ear and source phase response, what you hear or measure changes as you move around and if the wind blows, you hear the comb filtering inherent in the array's destructive / constructive interference principal of operation.
The down side is the correction for mix position is not right everywhere else, the best case is some kind of average.
The fact that the sources never do add completely, especially if the array is curved (when they generally radiate more acoustic power sideways than forward) is why they need delay rings, no way to have a working distance of 400-800 feet with a concert array.
Line array folk lore says you need them for "throw".
Best,
Tom
Thank you...QEDIf your anecdote's aim was to demonstrate the proposition that even a 'genius' amp designer can make generically dubious claims about audio: success!
Do you think Genelec put her speakers in an oven?Durability can be, if not measured, at least estimated. It is common to stress-test products by running them in conditions that accelerate ageing, such as high ambient temperature or supply voltage above normal.
I don't found links about the climate chamber used by Genelec.Chances are Genelec does test in climate chambers (not an oven) where one can control humidity and temperature.
You shouldn't take me for a pigeon.Manufacturers don't typically publish their full test protocol. That doesn't mean they don't test things.
