- Joined
- May 31, 2020
- Messages
- 872
- Likes
- 1,563
Absolute bs.By contrast, D&D measure pretty well, I've never heard them sound anything but awful.
Until another manufacturer does it better?How many times do we read things like clearest midrange, or sweetest highs. Sigh.
I have not seen new ones in a studio for a very long time. I do like the 50 with a sub.Clearest mid-range in the business, low distortion (that's 80% of the music). Major studios actually listen before buying what else do you need?
Can you explain what you mean by this? Are you implying that distortion is the most important thing in a speaker, with all other audible aspects like frequency response being the remaining 20% by rank of importance?low distortion (that's 80% of the music)
By far the largest variable in my system is the variability in the product that studios make, including within the same release. I definitely need way more that anecdotes and a few measurements of the nice midrange driver. Good measurements tell us about the speaker and how it will sound in various implementations, how it will interact with various rooms, and how amenable it will be to be EQ'ed to a target.Major studios actually listen before buying what else do you need?
A typical 3" dome can't crossed as low as the ATC SM75-150. If you can cross low where the 15" won't start to beam and won't resonate or distorts, then it can work. This is how ATC did and still does.My attempts to cross over a similar sized midrange to a 15" woofer was entirely unsuccessful, and not because of distortion.
Exactly.A typical 3" dome can't crossed as low as the ATC SM75-150. If you can cross low where the 15" won't start to beam and won't resonate or distorts, then it can work. This is how ATC did and still does.
I have never used the phrase sweet highs.How many times do we read things like clearest midrange, or sweetest highs. Sigh.
Yes, I am implying that the lack of distortion in the mid-range is what is most important.Can you explain what you mean by this? Are you implying that distortion is the most important thing in a speaker, with all other audible aspects like frequency response being the remaining 20% by rank of importance?
The ATC midrange dome is nice. It's been tested by itself, including off-axis and distortion, and has good properties. So do many other drivers. A driver doesn't make a speaker.
Many of us are confused by the crossing over of the dome to a 15" woofer. There are some physics, directivity being a major issue. especially crossed over to a 15" woofer. For instance:
Hence the question, how come there is no reasonably complete set of measurements for an expensive speaker that has so much anecdote?
I just selfishly want to see them.Yes, I am implying that the lack of distortion in the mid-range is what is most important.
Are you implying that a company with the experience, longevity and reputation of ATC don't do measurements?
Concerning the low crossover point to the 15 inch drivers Altec and Tannoy have been doing it for a long time.
I hope that everyone making comments on this post have actually auditioned the ATC line.
If I were to buy speakers strictly by measurements, I would have had to buy some kef blades or whatever. Nice life style hifi, but hardly high end audiophile gear.
Perhaps studios get data, or choose in other ways. Whatever their arrangements they’ve been around for a while and there’s no reason to suppose the 100 or 150 is significantly different to the 50 except in bass extension and total output, surely?
Martin Colloms measured the SCM50 in Hifi Critic, reprinted here…https://atc.audio/wp-content/uploads/2018/01/Hi-Fi_Critic_SCM50PSL_WEB.pdf His later review of the Actives references the earlier test and highlights the differences…
The frequency response looks great (+/- 2 dB) for the SCM50, nice and even on and off axis. I'm sure the larger models will measure similarly but with higher SPL capability.
Did he give a reason for that?Their US distributor stated that he at least will never send a model for measurement.
One of my parent's neighbors sold his Neumann KH420 - which measures superbly - to buy the ATC SCM 110, which I think is similar to the 150 in terms of spl and extension. He's happy with the upgrade.Smaller ATC speakers measures pretty good too.
Here are the measurements I did for my ATC SCM11:
What about crossing the dome over to two 10" woofers like in the SCM 110? The person I mentioned up above who now owns the 110 also spent some good time listening to it side by side with the 150, and he came away preferring the 110. Might the directivity matching between the dome midrange and the 10" woofers be a contributing factor to his preference?Many of us are confused by the crossing over of the dome to a 15" woofer. There are some physics, directivity being a major issue. especially crossed over to a 15" woofer. For instance:
Very possible explanation.What about crossing the dome over to two 10" woofers like in the SCM 110? The person I mentioned up above who now owns the 110 also spent some good time listening to it side by side with the 150, and he came away preferring the 110. Might the directivity matching between the dome midrange and the 10" woofers be a contributing factor to his preference?
