Tell Us About ARC plugin for DSP in the Home Studio
Eric Natural
Michigan
Interesting that it's in VST form - seems a perfect add to my master bus in Ableton for mixing/mastering. Have you used this to "room-correct" your studio ? Feedback ?
It looks dead (not developed).
It must be the least talked about DRC ever.
It started build-in into a KRK audio interface that nowadays nobody even knows existed.
Then it seems the system was sold to another company where it gained even less attention.
If you want something in your DAW you can use Sonaworks...at least that's what most people use in their DAW.
OR, you use your filters in any convolver on the monitoring bus. I did this for one project, but using it in EqAPO tasked my CPU much less, even if that means I can't use ASIO.
The reason for this DRC : I went from 5" monitors to 8". Calibrated with the mic at 21 points near my head and am finding a much smoother low-end using the ARC3.
Think that I'll keep it on my master bus for mixing.
Cheers
ARCv.x has come out w/free update v3 users. I can't comment on A vs B in room beyond the bass end is perhaps more defined . . .
Cheers
