TANCHJIM Space Portable Headphone Adapter Review
Rate this DAC & HP Amp
    Votes: 1 0.4%
    Votes: 3 1.1%
    Votes: 34 12.1%
    Votes: 244 86.5%
Colorado
Will the space outperform my lg g8x quad dac and amp?
I have the LG V60 with the same (or similar) DAC/Amp. The Space does indeed out perform the built in headphones for power, even in unbalanced mode (standard 3.5mm). When using balanced phones/IEMs it's not close in terms of sheer output. As far as the DAC quality, I can't personally hear any difference, but I haven't measured anything (they both sound great). It would be interesting to get some actual measurements for the G8X/V60 series.
Eddie
Anyone having issues connecting to PC? It lights up and then turns off immediately.
Do you use it on Windows 10/11? If so does it work with WASAPI? And does it "pop" when starting to play or when stopping or when changing the sample rate?
Eddie_Vanjovi
No, no. I just had it in a usb port that didn't have enough power.
s9_0d1n
Romania
Anyone else having problems with a changed OTG cable + tanchjim space?
More specifically I'm trying to replace the default cable with a 90 degrees variant from DDHIFI and don't get any sound out of the thing.
The 90 degrees cable helps me a lot when using with a phone...it makes the phone much more "pocketable" without risking undue stress to the usb C connector and socket while the phone moves in my pocket.
The variant I'm using is in the picture...link found here: https://www.ddhifi.com/productinfo/401430.html
I tried with another "normal" USB C cable from another adapter and that one doesn't work either.
Anything all that "special" in the default cable that I should be aware of?
Jimbob54
Just tested. Swapped for a generic no name black USB C to USB C cable , works fine. Maybe a setting on your phone? I dont think the no name cable is OTG, maybe that needs you to change the USB settings on your phone to data not just charge?
s9_0d1n
Romania
Just tried again, first with my Dell Precision laptop+Tidal app (worked) and then with my samsung phone + UAPP (worked).
Not sure what was different as I didn't change any setting on the phone, must have made an incomplete connection of some sort last time, even though UAPP detected the insertion the previous time as well and asked if it can "take exclusive control"...and I allowed it to, it was just not playing sound :).
Oh well, if it happens again I'll dig further ... if not, I'll be happy it's working.
Thanks for testing!
staticV3
Take a look at the xDuoo X-C12: https://xduoo.net/product/type-c-to-type-c-audio-cable/
It's even more compact for even less stress on the Type-C plugs. I use it with my phone all the time and I love it!
MCH
Need to find the right size though. The one in the picture is for relatively thick devices, but probably fine if you use a protective case for your smartphone.
If too thin, you can glue some foam to it until it fits.
s9_0d1n
Romania
Thanks, will look into that one if the current one breaks or becomes wiggly.
Although the ddhifi one seems "nicer" in terms of build and there's a local store carying it, which is helpful for quick replacements :).
Getting Chinese or US stuff in Romania (EU in general I guess...) takes a while and usually means paying customs fees and VAT on top of sales price.
FDM
Buenos días. Soy nuevo y no tengo conocimientos de acústica electrónica, así que no soy de mucha utilidad. Pero he recibido el Tanchjim Space y quiero compartir las imágenes del software que lo acompaña por si le sirve a alguien. Un saludo
Veri
Good morning. I'm new and have no knowledge of electronic acoustics, so I'm not much use. But I have received the Tanchjim Space and want to share the images of the accompanying software in case it is useful to anyone. Best regards
Thanks for the screenshots. Please translate back to the forum language (English) in the future, so all can understand :)
Cheers
FDM
Perfect no problem. By the way, the filter that appears in the image is the one I have chosen. Surprisingly, there is quite a difference between the filters.
multiformous
If you'd like the light to stay on, you can change that setting using the app. Not sure if that's possible just using the buttons on the device.
Jimster480
Tampa Bay
Are these still really available? I only found a page by searching directly and it says its a "pre order product"
Reactions: SMc
delta76
Yes https://shenzhenaudio.com/products/tanchjim-space-dual-cs43131-portable-usb-dac-amp ?
