Hi there, and welcome! What speakers are you using these with? With any normal speaker, you’d think this kind of stuff isn’t needed. It may be useful to accompany large format compression drivers in big horns. Generally if used with speakers that already cover the same range, you can expect some interference happening due to the center to center distance being too large. This may be an interesting effect, but will certainly not give you a faithful reproduction.I have just bought a pair of fostex t90a super tweeters and are wondering the best way to wire them in capacitor or crossover as have never done something like this before any advice would be greatly appreciated
I would ask first what are you trying to achieve with the supertweeters? As has been mentioned by others above, modern loudspeakers already go reasonably flat to 'supertweeter' frequencies, so adding supertweeters won't accomplish anything that can't be done with a slight twist of the treble tone control, or indeed an equaliser.
Also as mentioned above, most supertweeters start below 10kHz, so their effect is immediately obvious, and won't be an improvement in accuracy.
In my view, a solution looking for a problem.
I am using klipsch r50pm speakers with r121sw sub being as they are active there is no way that I have found to do these minor adjustments was recommended these because they work well with bookshelf speakers or so I was toldI would ask first what are you trying to achieve with the supertweeters? As has been mentioned by others above, modern loudspeakers already go reasonably flat to 'supertweeter' frequencies, so adding supertweeters won't accomplish anything that can't be done with a slight twist of the treble tone control, or indeed an equaliser.
S.
I'm using klipsch r50pm bookshelf speakers with a 12 inch r121 sub thanksWelcome!
Not something I've done, so I have no input on how to best wire it in. I do wonder what led you to doing this? What speakers are you using them with?
I am using kilpsch r50pm bookshelf speakers with a r121sw 12 inch subIn the first wave of 'Super tweeters' (I'm thinking of a lozenge shaped Tannoy one from yesteryear), they actually came in at a very audible 8 - 9kHz so their addition was obvious. These days, fancy tweeters go out to 40kHz or so, some often with nasssssty razor sharp peaks at around these supersonic frequencies (KEF/B&W to name but two brands).
So, if you want to go ahead, easiest way would be to put a series cap (no real idea of value but 0.5uF may be a starting point). No idea what speakers you have, but as I said above, the tweeters you have may well negate the need for re-enforcement up top![]()
I don’t see a reason for a super tweeter for these? Why do you think you need one?kilpsch r50pm
This is what I did with 'em in my quest to add some tippy-top treble to Altec 604E Duplexes.I have just bought a pair of fostex t90a super tweeters and are wondering the best way to wire them in capacitor or crossover as have never done something like this before any advice would be greatly appreciated
This makes sense. The speaker alone cannot do 20 kHz on its own.This is what I did with 'em in my quest to add some tippy-top treble to Altec 604E Duplexes.
bought these "tweeter arrays" back in the day. eventually gave them to a friend, who i think still uses them.Supertweeters in the 1980s...
source: https://hercshideaway.blogspot.com/2015/03/herc-loves-dak-part-three.html
This post is meant as a joke. A joke, OK?!Although these DAK/BSR abominations, like many others, really did happen. It was the '80s... interesting times.
Perhaps that's so with a commercially pre-built pair of speakers (e.g. KLH, Wharfdale, et al). But in my case, for the custom design Troy Crowe will build for me I need to decide between going with a two way system using this driver https://www.usspeaker.com/radian 760neoBepb-1.htm or a three way using one of these midrange driversAs has been mentioned by others above, modern loudspeakers already go reasonably flat to 'supertweeter' frequencies, so adding supertweeters won't accomplish anything that can't be done with a slight twist of the treble tone control, or indeed an equaliser.
Just for your reference, let me share the links to some of my major posts on supertweeter FOSTEX T925A:
What worries me about a three way are warnings from thread members at diyaudio.com about lack of coherence. And while it may help improve the T925A's performance in other respects, this waveguide will likely to nothing to overcome placement limitation issues.
Fostex T925A Super Tweeter with ES-2000 Circular Horn
DIY Speaker building for the hobbyist showcasing original designs by Joseph Crowe including acoustical measurements.croweaudio.blogspot.com
While I applaud and am well impressed by your extensive experimentation towards perfecting directivity of the T925A tweeter, would success absolutely depend on a DSP solution?
