AndreaT
Well, it is always possible to find better choices. However, they do recreate the sound I hear at Symphony Hall reasonably well. I guess it also depends on positioning them right (one sub takes ten hours, two subs one hundred, three…too complex). The double bass and organ at the opening of “Sonnenaufgang” of Also Sprach Zarathustra in a good recording is reproduced fine (31.5 Hz) in my listening room. Measuring a sub in a review is mostly academic, as they interact significantly with your room acoustic. Luckily, the open room has open extensions in the rest of the house longer than a 20 Hz wavelength (17 m). I think this matters, a lot.Not better made than others particularly. My DIY subs probably do better in that respect. Never been impressed by their performance in any case, let alone their relatively high expense for the performance (at least in the US). Just not one of the better choices IMO.
If you suggest I should further improve and upgrade my Strata III you are probably right…what do you suggest and what is your reference music for testing subs?
