Greetings!
I am new to Denon and Audyssey Multeq XT32, coming from years of different models Yamaha's receivers. I am witnessing some strange effects in my Denon RVA-X4700H based system, which were not present in any Yamaha receiver I owned in the past. Maybe some of you folks will shed light on these:
Thank you all!
- Applying any sound mode makes the sound louder, maybe by about 3dB, compare to direct mode. This is regardless of the input format: for example, if the input format is DD and the mode applied is DD, the effect is still there.
- Consider a dialog going on. At certain moment, when a background music starts, the dialog volume (only!) drops down, maybe also by about 3dB, and then gradually, within 2-3 seconds, returns to its initial level. This happens only when a sound mode is applied, never in Direct. I tried turning ON/OFF different Audyssey features without any success to catch which one is causing the effect.
Thank you all!
