This is my first post, it will take me a while till I get the hang of what is going on here but I am presuming my 2 cents contribution worth should help the theory in order to compile that list of best amps under $200. To make up for it, ill try digging deep so some of the experts can chime in with some information on the chip-sets and other reasons for my answer which in turn might help us choose a better amp.
I have bought the FX Audio 1002A, The Dayton DTA pro, Dayton APA150 and compared it to my old NADC356DAC and to each other. I tried both the FX audio and the Dayton APA150 with the Dayton DAC01 and with my NADC510 a 1k preamp.
To start with the NADC510 sounds digitally and very harsh to me, I never use it, sometimes its hooked up with a analogue crossover in between and my NAD356 as a power amp on the end. This has been scrapped for the NAD356 with the crossover in-between the Pre and power amp section. Crossover is to crossover two 12inch subs.
Moving on, The APA150 class A/B beats the FX audio class D amp with a range of speakers from small to large 3 ways. The NADC510 definitely helps out the APA150 with distortion and overall quality but does nothing to relieve the FX audio's dull and very bassy and nasty low end. The Dayton DTA Pro is my favourite but it can't power medium to large bookshelfs at 50 watts per channel its pretty weak. But when connecting it up to my Bantams micro speaker honestly, the bass reproduction the transients on that small Bantams the overall quality of sound was something that the APA150 didn't match but this was on the Bantams once you switch to a larger speaker and increase the volume the APA150 stood out.
TAS5342A TAS5508C these two chip sets don't seem to be used on any of FX audio's gear in general further research leads me to believe that Dayton chooses the better chip-sets and configures their own schematic and FX audio is the one who assembles them in China for Dayton. I am guessing not a 100% sure. And as Dayton buys in bulk Daytons products are beating their Chinese counterparts with prices. As individuals purchasing one item we choose the Chinese option as they are cheaper and end up with there low end gear which is not the case as the Dayton DTA Pro is cheaper and significantly better at its price point the closest FX audio counterpart is the D2160 which sells for $180 using a TA5614 TAS5548 with both amps using the PCM1808 for the DAC. This is a pity as you would hope that China would try and beat there competition by selling us the better amp for cheaper so we stick with them for business but it seems the US does it again somehow.
Ultimately in this bunch you get what you pay for, the NAD356 is the best, with the NADC510's sharp sound not for my liking. The Dayton DTA Pro should be tested, i don't have it at this time but if purchase another one I will send it to Amir and then he can post it to me. The DTA pro and APA150 need more A/B testing to see which one is better sonically but no doubt powering the micro speakers the DTA pro shinned. Also, the FX audio cuts out/clips on some speakers could be due to the slight drop in ohms, I have brought this up with the company.
I have purchased a preamp from FX audio and will hook it up to the APA and the FX100 to see how it helps the power amps.
Disclaimer. FX audio does good business and I will keep trying there equipment. I need to know if similar equipment exists from other companies is sold with slightly better quality for similar price. I understand that they are cheap and there not bad at all, the FX 100 powers up my massive Amiga MT towers and they sound okay but like Amir says can i recommend it or use it myself? No. Can I recommend the APA 150 for speakers under 300 or 400 dollars. Yes.
