Snake Oil Department, Top This
Sal1950
The Chicago Crusher
Central Fl
Bah Humbug !!!
EDIT Some more : Pretty much every search result is from 2015 - and most seem to roundly mock it like the video below. If anything should persuade you that Sony is not the company for you, the fact that they have moved in this direction (even if 8 years ago, and even failed), it should be this.
That sissy Fonzie doing the stunt on 2 ski's
Probably took him 2 months to learn to do that. LOL
Palladium
Even if you accept the "SD cards can alter sound even if the files are exactly the same digitally" premise, then why it's that so contrived that it only applies to just the card itself while also not applicable to the zillions of integrated and discrete circuits right beside it built on the same EE principles?
fpitas
Northern Virginia, USA
Once you can warp your beliefs to that point. you'll probably buy anything.
fpitas
xaviescacs
La Garriga, Barcelona
I have a practical question though. What is the SD supposed to store? Music? But, why put your music in an SD card? To expand storage of portable devices?
GGroch
Denver, Colorado
This guy had it right in 2016: "Marketed to those audiofools who will spend anything to make it sound better. And you know what, it is going to work...cause when you pay five times the price for a memory card, you are going to hear the difference. Link
antcollinet
UK/Cheshire
There is no end to it. But let's not bring the madness of other fora here.
DonR
Vancouver(ish)
DonR
Vancouver(ish)
I know, our 75" Sony TV decided to go 3D on us over the summer.
3 years old and it delaminated. Sony says it's not their problem, so won't be buying from them again.
I had a CD player from the early 90's that worked a treat for over 20 years until I sold it. Built like a tank. I think Sony is mostly a brand name now.
kemmler3D
San Francisco
Good lord, the replies to that comment... somehow I was expecting "no, you fool, it's placebo" but they actually doubled and tripled down on the concept. Apparently now 3GB buffers sound better than 2GB and 4GB sounds better than 3. So... if you only read audio into RAM every few hours instead of every few minutes, it improves the sound quality?
Thanks for reminding me why I haven't gone over to Head-fi for a few years. I'd have thrown too many perfectly good keyboards out the window if I did.
Sal1950
The Chicago Crusher
Central Fl
My $4k Sony XBR75 blew up at 8 months, it was replaced with a refirb'e set that was never right.
I replaced it with a 85" Samsung in May for half the money. I only hope is it lasts twice as long. LOL
Victor Martell
TBF - That is the case with consumer electronics - Sony HAD the reputation of being an exception, but current market conditions are the great equalizer - everything is built in the same spots, quality similar. After many years of buying nothing but Sony for my consumer stuff, like (mostly home theatre, but also car audio which I don't care about at all) I switched to Samsung and LG - lucky with Samsung, not so much with LG, but I've heard the opposite... guess with that stuff... it's all about luck...
:D
