Bah Humbug !!!
Home
For the audiophile who has to have it all, Sony is now offering an SD card that claims to offer 'Premium Sound', ideal for its new range of high-end, high-resolution Walkmans.www.whathifi.com
EDIT Some more : Pretty much every search result is from 2015 - and most seem to roundly mock it like the video below. If anything should persuade you that Sony is not the company for you, the fact that they have moved in this direction (even if 8 years ago, and even failed), it should be this.
Once you can warp your beliefs to that point. you'll probably buy anything.Even if you accept the "SD cards can alter sound even if the files are exactly the same digitally" premise, then why it's that so contrived that it only applies to just the card itself while also not applicable to the zillions of integrated and discrete circuits right beside it built on the same EE principles?
YesBut, why put your music in an SD card? To expand storage of portable devices?
Doesn't look like a billion dollar business... it's kind of a corner case...
There is no end to it. But let's not bring the madness of other fora here.View attachment 321004
Can the Read Speed of Micro SD effect Audio Quality?
I dont think it has anything to do with Card speed. The difference between reading from internal Flash memory and from an SD card is that reading from an SD card will add another layer of jitter... or simply jitter created by the additional current used or surges when reading from the SD card...www.head-fi.org
I know, our 75" Sony TV decided to go 3D on us over the summer.Sony is but a pale shadow of its former self.
He omitted the obligatory "the bass was tighter". Head-fi review FAIL!View attachment 321004
I had a CD player from the early 90's that worked a treat for over 20 years until I sold it. Built like a tank. I think Sony is mostly a brand name now.I know, our 75" Sony TV decided to go 3D on us over the summer.
3 years old and it delaminated. Sony says it's not their problem, so won't be buying from them again.
Good lord, the replies to that comment... somehow I was expecting "no, you fool, it's placebo" but they actually doubled and tripled down on the concept. Apparently now 3GB buffers sound better than 2GB and 4GB sounds better than 3. So... if you only read audio into RAM every few hours instead of every few minutes, it improves the sound quality?View attachment 321004
My $4k Sony XBR75 blew up at 8 months, it was replaced with a refirb'e set that was never right.I know, our 75" Sony TV decided to go 3D on us over the summer.
Live with my money while audiophools can part ways with their money, none of my businessNo way....
First check: it's not fake nor joke...
Second step: live with it...
TBF - That is the case with consumer electronics - Sony HAD the reputation of being an exception, but current market conditions are the great equalizer - everything is built in the same spots, quality similar. After many years of buying nothing but Sony for my consumer stuff, like (mostly home theatre, but also car audio which I don't care about at all) I switched to Samsung and LG - lucky with Samsung, not so much with LG, but I've heard the opposite... guess with that stuff... it's all about luck...My $4k Sony XBR75 blew up at 8 months, it was replaced with a refirb'e set that was never right.
I replaced it with a 85" Samsung in May for half the money. I only hope is it lasts twice as long. LOL
