SMSL SU-9 Balanced DAC Review
Count Arthur
It would be great to see some tear down of these dacs. Apart from the measurements I've always considered SMSL built quality not at Topping level..
I wonder if these companies have their own, in-house manufacturing, or whether they design them and then have the boards and cases produced by specialist fabricators.
bennetng
If all manufacturers are using the exact same 7 pre-programmed digital filters it would be weird that they show differing attenuation strength each time :p I feel like we're missing something.
tmtomh
Wow, this is an absolutely killer unit. Top-shelf performance, balanced inputs, nice display and form factor, remote control, reasonable price. Very cool!
voodooless
Netherlands
ESS datasheets tend to be confidential, but I don't really know what there is to deny. They're most certainly configurable, just like THD compensation. Wouldn't it mean SMSL is just using their own coefficients? I'm not saying it makes sense but it's one possible explanation.
Occam's razor has something to say about that.. As for confidential datasheets: Google doesn't seem to care :facepalm:
The performance of the existing ones should be much better, and definitely should vary from filter to filter. Here they are all stuck at the same stop-band, with the same type of spectrum. Most of them should actually be sub -100 dB.
One thing that might be of influence is the MQA decoder. If it would always be active in some capacity, it might always do some kind of upsampling. In that case the MQA decoder would also provide the 7 filters. Though it would be very coincidental that it's exactly the same number of filters that the DAC chip already offers.
anmpr1
To your last point: waifu dries fruit--looks like the same dryer you use. Try adding some pumpkin pie spice or cinnamon to the fruit prior to drying. Very tasty.
RichB
Massachusetts
It's a great time to be shopping for a DAC.
Do you have internal pictures?
- Rich
Cahudson42
Personally, I have trouble seeing the value for $440.. Maybe two years ago..ok. But today I think a good case can be made 'DAC solved' for $200 and under..
Now if it had included an L30 equivalent HP amp, and a 10-band PEQ...maybe..
Even so, Qudelix 5k ($110) + L30 ($140) = $250 = lesser SINAD DAC (likely) but PEQ room, speaker, HP optimisation ability. Plus HP amp.
beefkabob
Do we have an SMSL member on the forum who can explain why there’s no WiFi input? BT at best is still lossy.
It's not a streamer. They'd have to add a whole additional layer of hardware and software. The prices would probably be 400 more, at least. And then they'd have to support it.
HerbertWest
The best read for my morning coffe!
There may be a latency penalty though so if you are using Toslink for TV sound input, you may need to play with that. Fortunately the jitter that was there with default setting was not an audible concern anyway (at -120 dB and heavily masked by the signal itself).
Out of curiosity, is this latency penalty quantifiable?
Thank you!
gvl
SoCal
Google Chromecast Audio was priced at $35, it was on sale for $15 just before they stopped making it. And that was a complete shrink-wrapped product with a built-in DAC. Why no one licensing this tech from Google to use in their devices?
AudioSceptic
Northampton, UK
It's not just the number of filters. Look at the Pro-Ject filters I referred to above. They have the same shape as the SMSL ones, and are different only in the ultimate attenuation (and one extra option). The Pro-Ject also decodes MQA BTW.
D
Deleted member 19195
Guest
If it had a 12 v trigger, it would be exactly what I am looking for in a pre amp. I assume it does aptx hd and ldac?
Jimbob54
Indeed . But Im hoping for a near future where anything like bare bones DACs (D10 and under) get absorbed into amps/ actives and standalone DACs incorporate any number of connectivity/ EQ / widgets over and above the usual hard wire digi inputs and outputs. Nearly there but not quite.
MediumRare
Chicago
Amazingly, a $300 amp can do all that at 100 wpc (Yamaha R-N303) but not a $440 stand-alone DAC!
