Hey Guys, after lots of thinking I decided it's time I spend more money...
I currently have an RME ADI-2 DAC v2 with my AHB2 to B&W 702s2 and I am extremely happy however I have a second setup at home (yes, my primary setup is in the office where I also have the room treated nicely) which currently has a Chord Hugo2 (this was before ASR times...) going into an Audiophonics Purify S400ET off to some PMC Twenty5.23.
I still like the Hugo2 but I am using it purely as a desktop amp since I bought an e1da 9038s v3 (which I use with great satisfaction mainly with Etymotic er2xr), so I will most likely sell it shortly (from Europe).
In both cases, I am not using any preamp which is where I would like a bit of advice. I am thinking of moving the RME at home to pair it with the purify and enjoy also the very good headphone out and buying another DAC for the main setup in the office. The SU-9 seems like a very interesting solution (also looking at the M500 v2 or today's newly reviewed Gustard X16) however I am a bit puzzled about the output voltages and what is the best option because of output voltage and amplifier gain settings.
I am able to listen to loud volumes with the AHB2 on low gain and RME ADI-2 DAC on auto ref which should always maximize sinad and I am afraid that with the SU-9 I will be forced to go to medium gain settings thus losing a few DBS.
I realize that I can put a preamp in the mix and always feed the AHB2 (or the purify in opamp bypass mode) with 9V but isn't the preamp going to have a negative influence on the overall SINAD anyways?
All of this to ask the following within context: 1. Preamp between SU-9 and AHB2 yes or no? 2. I've read somewhere on the forum (but can't find anymore) that the DAC should always be at least a certain number of DBs better than the amplifier to get max performances, this is the main driver in this switch, do you remember this number and maybe have a link to a post with the explanation?
Of course, I do realize that we are talking at minimal, and most likely inaudible, differences but in my audiophile journey, I learned that what measures better, do sound better to my hears so why sacrifice even 2 or 3 DBS when you can avoid it?
Yes, I know... I should stop the nonsense and just enjoy the music but I am a geek with a strong tech background, nothing can save me.
Last but not least, if you believe my logic is flawed and that I a missing some background knowledge I would be really glad if you can point me in the right direction so that I can study and fill my knowledge gaps. Any comments on the above are really welcome.
Thank you very much for the time you spent reading this. Truly appreciate it.
Z.
