SMSL SU-8 Version 2 Balanced DAC
renaudrenaud
Tianjin
Hello community!
Does it still going strong in 20024? Wanna upgrade my old SMSL M3, that i use with Android phone to listen flacs via vintage amp and speakers, also through small Xduoo 602 HP amp.
Looking at this SMSL SU-8 and SU-1. Will be there a noticeable difference / worthy upgrade? And which one is definitely a better choice?
Why not the SMSL M300-SE?
Price is very low, XLR outputs (and RCA) and also 2 headphones output, better screen than the SU8, a button for volume and settings, Bt...
Loftrocket
Well, i'll take a look at it too! Thanks.
Loftrocket
Exactly, maybe you'll notice an improvement by upgrading other components like Amplifiers or Headphones
At this moment i need just slight upgrade to my current setup. After big repairing of my future living place there will be different toys. Well, i guess i'll try one, 80 Euri is not that money to regret. And it's Amazon, i can return it. :)
Is SU-1 the best sounding device in this price range?
JRG123
SU-1 is a DAC with excelent measurements and you'd probably won't need to buy a DAC anymore, for that price is a steal. But like I implied before, I don't think DAC's sound different, SU-1 and SU-8 are both transparent enough and with great features, you just need to look for the ones you really need :)
