helloworld
- Joined
- Jul 10, 2018
- Messages
- 220
- Likes
- 194
I heard you can fixed the problem by yourself if you know a little bit of electronics with the old version. You only need to change the connections of the three wires connected to the switch. Be patient they will tell you how to deal with the wire connection. By the way, actually mandy has said that the old version they purposely designed the best listenning condition is around or less than -6db, when amirm test with 0db it showed poor performance because of the power supply could not drive high enough voltage. It will show similar thd+n results as v2 if amirm test with -6db.
