Well that's disheartening since I ordered the m400 too...My SP400 has less volume output than my SP200.
Is this to be expected with the lower gain on SP400 (11.6db) vs SP200(18db)?
I assumed that it would get louder than my SP200.... Maybe something to do with the high output impedance of my M400?
-are you using SP400 balanced?My SP400 has less volume output than my SP200.
Yes balanced in/out. Same exact setup. I have an XLR switch, i can just switch between amps. SP200 is significantly louder than SP400.-are you using SP400 balanced?
-if same set-up? 6.4dB less gain is significant
Can you jump up to a Topping A90? It has proper RCA pre-outs as well as some of the best amp performance. Using XLR to RCA adapters is not the best way to achieve single ended pre-out...I have questions regarding the SP-400 as a preamplifier for my main system (speakers and headphones). Since SP-400 has only XLR out and my amplifiers (Crimson 630c) are single ended, I would need to use XLR to RCA cables. Can anyone here tell me if this is a serious compromise in terms of sound quality and compatibility? Also, has anyone used the SP-400 as a preamp in a speaker set up? If yes, is it a legitimate alternative to a dedicated preamp?
Any feedback would be most appreciated.
SP200 high gain at 12-1 o'clock is as loud as SP400 at 99 volume high gain.I also noticed the lower output. I remember when I had the SP200 I don't think I ever hit 12:00 in high gain. With the SP400 I'm at 50 (balanced) with the M400 at fixed volume (80). Kinda wish I didn't rush and sell my THX AAA 789 for this.
It doesn't make sense. Something has to off. Have people tried comparing with no gain since the sp200's high gain is significantly higher?SP400 output isn't low. It IS lower than the output of SP200.
Never in my life have I had an amp with TWICE the rated power of the amp its replacing, ended up being half as loud....
It does get plenty loud, just not as loud as SP200
So you could put the m400 at 99 or is 80 the max for whatever you're talking about?in the m400 stack it also depends on if you leave the m400 at 80, which is a little hot. my comparisons against my archel 2.5 were done at 4v (75)
the sp200 has a linear pot iirc which means it gets really loud really fast.
M400 maxes at 80. I set the "Pre Mode" setting to "fixed" which "locks" the dac at 80, and then i use the volume on the SP400 0-99.So you could put the m400 at 99 or is 80 the max for whatever you're talking about?
Gotcha. Trying to iron out everything before I get mine.M400 maxes at 80. I set the "Pre Mode" setting to "fixed" which "locks" the dac at 80, and then i use the volume on the SP400 0-99.
