Share your in-room measurements?
thewas
Does the 130 Hz problem appear in single speaker measurements? If not, I wonder on how much content this would be noticable. It would depend how often they mix to mono in that range. I've read that's typically done for bass but I'm not sure how high up that extends.
It doesn't appear in single measurements and thus isn't much audible, in contrary, filling up this peak makes sound muddy.
Snarfie
Netherlands
Attic V shape room dimension 7 meters (23 ft) x 4 meters (13 ft). Attice still underconstruction.
Did try most target curves in 95% of the cases the white flat target curve had te best (subjective) result for me.
Steve Dallas
A Whole Other Country
How did you levitate that tom to its place near the ceiling? Can you similarly levitate all the frequencies below 300Hz?
I was just pondering trying out the MathAudio RoomEQ plugin for the first time to see how it does. Amazing coincidence that I scrolled down to your post at the same time.
Snarfie
Netherlands
Still i want too master REW to hear the difference. Mathaudio room eq is not only freeware incombination with foobar but most of all elegant easy to use software. It let me Discover my music collection again. Did not thought the difference is that big. However when you have a lousy room acoustics as i have any flat corrected frequency respons will make a big difference. Hope you have a good linear measuring mic.
seamon
Raidho XT1 + Rel T5i Raw Measurements in my non treated room. The ~110Hz is a room resonance.
Measurements with Room Correction EQ:
I might raise my Rel T5i level by a bit I guess
Steve Dallas
^ I bet kick drums are a REAL punch in the gut without correction. What is going on between 2K and 14K?
Cool looking speakers!
seamon
I think it's trying to follow the Harman Curve. Not sure
Steve Dallas
I am wondering if the crossover point is ~2.2KHz, and you have broken tweeters?
That is definitely not a variation on the Harman curve. The Harman Curve typically tilts down ~5 to ~10dB gradually over the whole frequency spectrum. There are different takes on slope changes along the curve, but none look like what you have there.
Here is one take on the Harman Curve and the one I use (blue line):
seamon
So I moved the mic up by a bit and this happened.
Also this was the house curve I was looking at from this video
Speaker positioning is on the bad side as I just put these in so there's that too.
Edit: Legit not sure what is happening. Is this a phase issue?
Steve Dallas
Can you show us a phase chart of L, R, and stereo? You will need to measure a sweep to show phase.
(FYI, the emerging standard on this site is to use a 50dB scale on the Y axis for consistency.)
That Target curve is one of the most extreme I have seen. (Cannot watch the video right now, but I have to assume it is wrong, if that curve is their recommendation.) I think I see a -13dB drop from 1KHz to 20KHz. That should be more like -4dB.
Here is a thread that contains extensive information on target curves. It is definitely worth a read:
https://www.audiosciencereview.com/...ut-room-curve-targets-room-eq-and-more.10950/
Post 11 shows a graph from Toole's excellent book. The solid black line or the wide dashed line are what you want. The wide dashed line exhibits a ~ -10dB decrease from 20Hz to 20KHz.
seamon
That Target curve is one of the most extreme I have seen. (Cannot watch the video right now, but I have to assume it is wrong, if that curve is their recommendation.) I think I see a -13dB drop from 1KHz to 20KHz. That should be more like -4Hz.
Here is a thread that contains extensive information on House Curves. It is definitely worth a read:
Alright so I toed in the right speaker towards the center and this is what happened
OLD vs NEW
Compared to default REW target curve
Phase
Old
New Phase
Thank you for taking the time to help me out!
Edit: I'll get L and R phase charts with the new config.
L Channel Phase:
R Channel Phase
L+R Phase
Bear123
Desperately need subs with those it would seem.
Bear123
I have subs but just dialed in very low, I'll increase sub gain once I have this sorted out
Ah, that would make sense why below 100 Hz is missing. Didn't see any in the picture you posted.
Steve Dallas
Before we try to unpack phase...
It appears those speakers have narrow directivity, based on your graph of the one that is toed in. We can work with what that produced.
Toe them both in toward the listening position and re-measure in stereo Keep changing the toe of both speakers, from straight ahead to just past the listening position, while logging physical dimensions, until you determine the best position, return them to that position, and post that FR graph.
(We spend the time to get positioning as perfect as we can, then focus on correction.)
Also, I have attached a copy of the House curve file I use, which you may find helpful.
  • Harman -10dB.txt
seamon
How do I determine best position?
Also looks like these speakers might not be the best idea for what I was using them for(Extreme Nearfield Listening)
Steve Dallas
To determine the best position, in terms of toe, you start with them pointed straight ahead (which you would not do for nearfield), take a stereo measurement, toe them in an incremental amount (few degrees), take another stereo measurement, toe them in another increment, take another stereo measurement, etc. Look back at the measured data, return the speakers to that amount of toe that produced the best measurement, then start working on correction.
For nearfield listening, it is often best to choose speakers designed for that purpose, which are usually studio monitors. Genelec and Neumann are highly recommended if in your budget.
seamon
These are best I could do in my acoustically hostile environment(monitors on both sides of speakers).
muad
Try a moving mic measurement of the left and right speakers. It will give you more accurate picture of what the speakers are doing around your whole listening position. A single point measurement only reflects that single point.
https://www.avnirvana.com/threads/mmm-mouving-measurements-method-which-one-is-best-with-rew.6360/
richard12511
Whoah! That's a really strange looking response. The weird fall and rise in the treble makes me wonder if something might be wrong with the mic or mic calibration? What mic are you using?
Ignoring the measured response, do you enjoy the sound?
