I can understand you. But you should not give up too early, it's real fun to dig into a unit's performance.Thanks for the input. But I am tired. I will get the thing shared elsewhere if I have the mood some other day.
That frequency response analysis is meaningless for me on this to begin with. I just wanted to show 2 DACs can have difference. Not that I can get the same results with Amir.
However if you want to show differences between DACs you have to make sure that your ADC is good enough for this purpose. Therefore it makes sense to measure a DAC with known excellent performance so you can compare your results with the known ones. This tells you the limits of your ADC, and then you know that you cannot get better results than your ADC alone delivers.
Now if you measure a DACs and it has at least 10 dB more distortion and noise than your ADC you know that this result is close to the real value. To prove that 2 DACs perform different at least one of them should have 10 dB more distortion and noise than your ADC. If both perform better than your ADC you can't say whether they are different or not.
