You'd have to clearly define what "analog sounding" actually means first.My ears are not good enough to determine whether I think the sound is analog or not, sorry for that
Oh come on! Everyone knows that it means not digital sounding.You'd have to clearly define what "analog sounding" actually means first.
Thanks, I assume you don't have a (quality) CD player to do comparisons? If that ROHM chip in the D300 is good enough for Luxman it should be good enough for me!SMSL D300 is, according to some, an analog sounding DAC. I have one and use it. My ears are not good enough to determine whether I think the sound is analog or not, sorry for that. There is a thread at stevehoffman forum, where people claim it is analog sounding.
For me, it works fine. I enjoy my music a lot.
I only use COAX from streamer to DAC, so I have no issues like mentioned over here in the D300 thread.
The differences are subtle but enough to make the Modi unpleasant in comparison.
Well, there is no doubt my Sony turntable sounds analog, along with its cracks and pops and a low SINAD.Analog sounding, I always took it to mean a romanticized version of how something sounded from memory, like looking at the past with rose-colored nostalgia glasses.
In practice, not sibilant.
He moved on from Lyric to sell cars for Yugo, claiming their engine sound compared to that of a 911.I remember the salesman at Lyric Hi-Fi telling me, in 1987, that the kilobuck Esoteric CD transport made CDs sound “almost as good as a turntable
On a subjective audio forum you might hear that a Chord Mojo 2 sounds more "analog," or that DACs with AKM chips sound "warmer" than those with ESS chips
The only thing in specs that might make a slight difference with a low impedance phone is the two chips have different output impedance though I think the difference too small to matter. Otherwise I'd guess the filtering is different in each. Don't know which is available and which you used, but do you hear a difference if you use steep filters on both? I also notice they show 10 hr runtime with the AKM and 14 hr with the ESS. Makes me wonder if one has more power than the other. That too might sound different if you used it with phones that like a little more power.Astell & Kern makes a DAP called the A&K Futura SE200. The interesting thing about this player is that it has both an AKM 4499 DAC, and an ESS 9068 DAC. You can switch between them and listen. I was surprised that I could hear a difference. I was keen to buy one and send it to Amir, but he declined to review the DAC because he felt that shipping would be too expensive and too risky. There is either something going on in that player to create that difference, or my hearing is playing tricks on me.
So basically if it's more than 115 then the rest is more like personal preference?You could run a competition like drag racing for pinks (for those not familiar that refers to the winner owning the loser's car after the race).
If you can pick the better measuring DAC in a blind test, you take mine... if not, I take yours.
Edit: Naturally you'd want to eliminate the really bad outliers... but maybe set a minimum SNR of 115dB or so.
I can not explain why it sounded different. The volume certainly sounded the same, but the AKM had a noticeable "warmth", just as the subjectivists describe. I have a strong bias towards all DAC's sounding the same, but I have to report honestly here. I don't know what is going on, and I am very keen for Amir to take a look at it. If I am lying to myself, I would love to know that too.
BTW, I do not own this player. I heard it at a shop. I would have to buy one for Amir.
If you mean personal preference for aesthetics, brand, price, inputs, etc. then "yes" - more than that and humans lack the organic equipment to determine audible differences.So basically if it's more than 115 then the rest is more like personal preference?
As I said, I don't have the ears for this. I don't hear the difference between albums played by any chain I use, whether it is streaming (Node 2i and D300) or Turntable (Technics SLQ2 and Vincent PHO700) apart from the occasional pops and clicks. Probably because I never learned listening to equipment.Thanks, I assume you don't have a (quality) CD player to do comparisons? If that ROHM chip in the D300 is good enough for Luxman it should be good enough for me!
I attended the Hoffman Music forum for about ten years. The link provided mentions quality problems with the D300, does anyone know if that's reflected in current units?
So didn't test blind - and probably not accurately level matched. And in noisy environment with surrounding distractions.I can not explain why it sounded different. The volume certainly sounded the same, but the AKM had a noticeable "warmth", just as the subjectivists describe. I have a strong bias towards all DAC's sounding the same, but I have to report honestly here. I don't know what is going on, and I am very keen for Amir to take a look at it. If I am lying to myself, I would love to know that too.
Thanks for the reply!As I said, I don't have the ears for this. I don't hear the difference between albums played by any chain I use, whether it is streaming (Node 2i and D300) or Turntable (Technics SLQ2 and Vincent PHO700) apart from the occasional pops and clicks. Probably because I never learned listening to equipment.
I know a guy who build a separate underground listening room next to his house, invested probably 100 times more money than I did in equipment and his room. He still is not satisfied.
The quality issues (also discussed on this forum: https://www.audiosciencereview.com/forum/index.php?threads/smsl-d300-review-balanced-dac.28919/) have to do with "upgrading" firmware, as far as I understand. I did not upgrade my unit. I use it as it came out of the box. Stream the music from the Node 2i (Qobuz, Spotify or FLAC files from a SSD) over COAX. No issues at all. I don't know if my unit would have issues using USB or Optical input, I never tried.
