It’s irrelevant what it is supposed to do. You didn’t level match, so all bets are off.Louder is supposed to sound better, however the Su10 is quiter than the P6.
The post you quoted and responded to. I'm sorry if I caused confusion by only quoting your response to it.What?! Who said ANYTHING about the Su9? You must be mistaken.
And audio opamps are designed so that the output equals the input times a constant. They are specifically designed for linearity (low distortion) and low noise. Unless they are implemented incorrectly they should be the least of your concerns in a DAC and will have no effect on humanly perceivable differences in the signal.I started with very low volume on both and only went up to about 40%. Also the measured output on the Su10 is 5.3v while P6 is 7v. So p6 is technically louder in volume.
Assuming dacs have no sound, fair enough, they're designed to convert digital to analog which in theory shouldn't produce different sound between units.Okay, but what about different OP amps between dac units? The Su10 has 21 dual-op amps, would those also not alter the sound between different dacs?
I did also listen to them with the p6 at lower lower volume as compared to Su10, no change.It’s irrelevant what it is supposed to do. You didn’t level match, so all bets are off.
That still no good. Matching has to be done precisely! And you obviously knew which is what. You cannot just disable biases in your head either.I did also listen to them with the p6 at lower lower volume as compared to Su10, no change.
Sorry one big thing about listening comparisons, sighted or not. Match volume levels precisely. To within 1%. That is JOB #1. Don't pass go, don't collect $200. If you don't do this step, your listening test is useless.I did also listen to them with the p6 at lower lower volume as compared to Su10, no change.
That's all the point.Curious if you hear difference between both dac’s.
I keep using my topping d90se dac, because I hear a little improvement over the A6 master version dac.
but some people keep telling there is no difference because the dmp a-6 is ‘transparent’……….
didn't even look at it because of the DAC it's using. (I know DAC chip implementation is more important than the chip itself but I didn't want a sabre DAC in the first place and this is why I didn't look at it)Don't forget the superb X26 Pro...........
GUSTARD X26 PRO Dual ES9038Pro Digital to Analog Convertor (DAC)
Product Specifications: Sample rate supported by digital input channels: COAX : PCM 16-24bit/44.1-192kHz; DSD DOP64 AES : PCM 16-24bit/44.1-192kHz; DSD DOP64 OPT : PCM 16-24bit/44.1-192kHz; DSD DOP64 USB : PCM 16-32bit/44. 1-768kHz ; DSD DOP64-DOP256; NATIVE DSD: DSD64-DSD512 IIS : PCM...shenzhenaudio.com
I've tried R26 but it was disappointment compared to X26pro. Nothing like bigger sound-stage was in R26 only troubles...didn't even look at it because of the DAC it's using. (I know DAC chip implementation is more important than the chip itself but I didn't want a sabre DAC in the first place and this is why I didn't look at it)
How does it compare to the r26 & a26? I'm not in a quest of having the most detailed & neutral DAC... I lean more to something which has big soundstage and is more musical than analytical if I can say that.
if you already have a warmish tube amp in your system maybe it's not the best idea to add a DAC which brings more warm to the system... this is what I meant with synergy. (just an example, not speaking about the DACs we are talking about)Good lord no, there is no synergy with a DAC. Seriously.
I understand that you are trying to be balanced and not make sensational claims, thank you for that; however, I think you will find that very few people in this community support the idea that a DAC can change or influence the perceived sound at all. Unless somehow it was absolutely flawed to the point that you would not want to use it. Why would a DAC have any influence on sound at all?if you already have a warmish tube amp in your system maybe it's not the best idea to add a DAC which brings more warm to the system... this is what I meant with synergy. (just an example, not speaking about the DACs we are talking about)
if it was the case, people would just buy the cheapest DAC right?I understand that you are trying to be balanced and not make sensational claims, thank you for that; however, I think you will find that very few people in this community support the idea that a DAC can change or influence the perceived sound at all. Unless somehow it was absolutely flawed to the point that you would not want to use it. Why would a DAC have any influence on sound at all?
The cheapest one that is transparent to you, all other things being equal (looks, build quality, reliability, customer service, functionality, etc.)if it was the case, people would just buy the cheapest DAC right?
