solderdude
requires a definition of measured transparent.In general the original question by the autor was not responded concisely: I let a resume of a few notes are taken to the question “how can DACs measured transparent can sound different?”
-They don’t (majority)
Can easily be measured. Consider that slow filters do not measure transparent so there's that ... and the age of the listener as well as the sample-rate.-Filters alters the sound (some members)
Depends on what is measured and how various measurements are combined to determine technical performance.-Measurements may fail to predict transparency (my suggestion that caused a lot of reactions, and probably audiophile believes)
Problems occur when trying to predict sound quality and subjective found differences due to the huge amount of possible variances opposite lab condition measurements.
It is this part that is questioned... your personal experiences in your situation.
I would suggest you stop buying ifi DACs... they do not seem to be your thing. We (as well as you) don't know the reasons for it.
Good thing there is such a thing as 'nulling' where one can even listen to nulls.-Other unknown variables (again my suggestion, same as measuring incompleteness but differently formulated)
