@Thorsten Loesch
Coming back to iFi, I intend to buy the iFi Audio NEO iDSD next year, probably I won't have an improvement in sound quality compared to the IFI AUDIO ZEN ONE SIGNATURE DAC.
Technically speaking, the "Neo" was based on the next generation entry level platform.
At iFi we had in effect three general "levels", later rising to four and I guess now five.
Originally they were labelled nano/micro/pro.
The nano platform meant 5V single supply analogue circuitry using charge pumps for a negative, single DAC Chip. The "Zen Range" was essentially a re-warming of the nano range, at a lower price/better build etc. Technically they are "nano" derivates
The Neo had a number of new design blocks, that were intentend to provide a new nano range. Specifically, on the DAC side it shares the design of the Zen DAC (which I consider a superior design to that in the "one"), except the addition of SPDIF & BT inputs. Improvements mainly apply to the headphone amplifier and variable line out.
The design brief was to provide a competitor specifically to the Denon DA-300 at 300 USD retail. So I feel at the current retail price it is not competive. Unless you need the SPDIF or BT inputs a zen DAC is a better upgrade.
Another option would be to use the Zen One as D2D converter with SPDIF Output and feed the output to the Musical Fidelity DAC you already have.
You could also look out for a second hand iDSD Pro, if you want a significant upgrade.
There are also other BB DAC based Units you can find (especially 2nd hand), possibly with better results than the NEO.
Finally, if you want to jump off at the deep end, there is a PCM56 non oversampling FAC floating around ebay and AliExpress at very low cost. It could be worth a punt, you might like it (I had nothing to do with that DAC, just in case).
Thor
