Sennheiser HD560S Review (Headphone)
Rate this headphone:
    Votes: 5 1.0%
    Votes: 31 6.1%
    Votes: 192 37.5%
    Votes: 284 55.5%
I found a pair for just over £60 GBP from an outlet so had to give them a go. Unfortunately the channels aren't well matched, perhaps the reason for being sold as a return in the first place:
About 1.5-2.5dB below 3kHz and 3-5dB above.
@solderdude what do you think, typical or not? It's the original pre-2022 version believe it or not, has the velour headband pad and different cable/adapter.
The difference in level is a-typical for Sennheiser.
Is it possible the difference can come from the used headphone amp and or mismatch between L and R of the test fixture ?
I had a careful look at the headphones and the right earpad is wrinkled and compressed compared to the left which looks new. I suspect this is the cause of the right channel SPL being measured higher as the pad being shallower brings the driver closer to the microphone.
I will return them and mention it to the seller and hopefully they can swap the earpad for a new one to resell.
FWIW I prefer my HD6XX although obviously it's not a fair comparison due to the above issue.
Hii, can anyone tell me how 560s sounds compared to he400se? Does it have the same problem of sounding tinny or too analytical? What can causes sound to fatigue
HD560S is a marginally bright sounding headphone but does not have the 'tinny' sound and has a bit more 'body' in the lows and does not fatigue.
EQ can solve most of the issues but the 'fatigue' comes from +10dB peaking in the 8-10kHz range and because the usual industry standard fixtures don't measure that properly the EQ generated from those plots does not address this issue.
I would recommend to EQ that band and EQ the bass up a little before buying another headphone.
Which headphone are you saying has large peaks between 8-10kHz? My HD560s doesn't have +10dB peaking in the 8-10kHz range. That doesn't show in my miniDSP EARS measurements, and nor does it show in "hearing tests" I've done with HD560s. I think that goes for both New Version & Old Version HD560s. Following is New Version vs Old Version on miniDSP EARS and there's no +10dB peaking between 8-10kHz: HD560s New Version vs Old Version.jpg
And here's my "hearing test" that doesn't show any 8-10kHz peaking: result of hearing test after ear microsuction.jpg. Part of my natural hearing has a peak between 8-12kHz which I've tested on Anechoic Flat speakers and I also hear it peaking in all headphones I wear, so I have a natural peak in my hearing between 8-12kHz, so that considered then I don't hear a real peak in the HD560s between 8-10kHz, and the hearing test doesn't show a peak there anyway.
My HE400SE could maybe be argued that there's an 8kHz peak HE400SE Channel Balance.jpg(although we have to be careful not to read too much into miniDSP EARS measurements when looking at something so "narrowband"), but I haven't tested that with a "hearing test", although I'd think I'd find it irritating if my HE400SE had a massive peak between 8-10kHz because my hearing has a natural peak in that range so I can hear that frequency range clearly. I'm sure the HD560s doesn't have massive peaks between 8-10kHz though. Yeah, so which headphone are you referring to, because it's not clear?
HE400SE..
HD560S is just mildly 'bright' (4-6kHz)
sorry if my post was unclear. I reacted to:
These are down to £99 in the UK right now, nice price!
This is very tempting indeed. I see there’s been two versions of these headphones? Is this the latest version that’s for sale?
I’ve been looking for something with a similar vibe to my HD650s - which I use all the time for music production and mixing, but never really for just listening and enjoying music. Tonally they sound great, but they’re just too narrow sounding for me to get immersed in the music.
Would I be onto a winner with the 560s?
It's worth trying at least. The 560s is a bit more forward and less smooth than the 650. For soundstage width/depth questions other users may be more helpful, I don't hear that much of a difference here. Imaging is good with both headphones.
HE400SE..
Yep, so you're saying the HE400SE has a peak at 8-10kHz, I thought that's what you meant but wanted to clarify for myself & others because very easy to think you were talking about the HD560s especially as this is HD560s thread too. I might do that "hearing test" on my HE400SE just to see if I get any different results there in that area in comparison to the HD560s....just because I don't feel troubled by that area with my HE400SE & am curious to confirm (EDIT: would be a bit tricky to draw conclusions from a comparison because they have different frequency responses around 1kHz and mids so they'd be quite a lot to bare in mind when comparing the results).
I think it's worth trying, and yes it would be the New Version that you'd get. At stock I find the New Version HD560s very neutral, so I think you'd like them given that HD600 & HD650 are also pretty neutral. You'll probably find the bass is better extended in the HD560s whilst still being neutral, so I think you'd enjoy that. You'll find the soundstage better on the HD560s too vs the HD600/650. I've got the HD600 and you're right it is narrow, so that's another win for the HD560s.
New Version HD560s is less forward than Old Version HD560s though, so there's that to consider if you're basing it on listening to Old Version HD560s.
Another dac/amp that sounds nice and controlled with hd560s - recent Creative G8 (with CS43198), been testing with rock, metal, blues songs all day, when i got it yesterday, hd560s seemed unleashed very well
HD560s is an easy to drive headphone though so power of the amp is not that important, so as long as it's an audibly transparent DAC/amp then you're fine, and you've probably got that with the G8 even though it's not been measured here on ASR. Amir did measure the G6 though and it looks like the G8 is sort of it's replacement in some ways (even though they're still selling the G6 from their website), so you'd expect the G8 to measure as well as the G6, and at least the audio technical specs are the same between the G6 & the G8 if you look at the specs on the Creative website.
Makes sense, was looking at G6's too, it has Cirrus Logic CS43131 chip, doesn't it, not that far from 43198 numbering, probably minor tweak of previous one. I used to have Creative E1 Portable, G3, Sound Play! 3, those felt lacking in all aspects of sound, with G8 i liked sound a lot in games and music, EQing options, and dual connection of PC+laptop option at once, someone tracked that you could do 4 connections at once and get sound from all 4, haha, but that's way too many
Could be quite cool if Amir was to measure the Soundblaster G8, but like I said good signs re the Creative Tech Specs indicating it'll likely perform as well as the G6 which measured pretty well in Amir's review.
I'll check my budget after i get back home next week, if i can send him G8 for testing, would miss it by the time he returns it, hehe
If you want to & you want to see those results then great! If you're gonna do it though, be happy that you're doing it first.
