Yawnny
- Joined
- Dec 20, 2020
- Messages
- 27
- Likes
- 14
Hey all.
I've hit a brick wall with my USB noise issue that has been introduced since I added the Schiit Vidar to my setup a couple days ago.
Only when using a USB Dac and Vidar do I get usb chirping/hissing/intermittent clicks/squeels
Using a USB DAC with an SMSL SA50 Class T amp I get Dead silence.
For troubleshooting, I'll hear the noise, unplug the USB cable from my Modi3+.. boom, dead silent
I'll take USB out of the equation by plugging my old school iPod Classic into the Nero Pre Amp.. beautiful silence.
Plug Modi3+ or SMSL Sanskrit 6th Ed back in.. chirping/hissing/ usb noise..
Is there something about the way Vidar is built that picks up on USB interference so much so then a little cheapo Class T SMSL SA50 amp?
Some Info about my setup:
Pre Amp: Audient Nero Monitor Controller (Have also tried Schiit SYS, Pre Outs from Audient ID4 interface, and 3.5MM out from the Macbook Pro)
The 3.5MM out from Macbook Pro introduces electrical noise with the Vidar, though not as bad as a USB Dac does
Source: Modi 3+ > 2018 Macbook Pro (Also tried SMSL Sanskrit 6th into Macbook Pro, as well as both the prior DAC's and a Windows 10 Desktop)
Here's some more things I've tried without success:
* Modi3 + > Powered USB Hub > Macbook Pro (or Windows machine)
* Swapping Audio Cables (RCA to RCA, and RCA to TS - lengths 6ft - 15ft)
* Swapping Power cables for the Vidar
* Phone is not near by (to try and cross off wifi interference)
* Ferrite Cores on Audio + Data (ie: USB) + Power cables
* Touched the top of the modi and Vidar to see if that changed the interference sound - it did not
* Made sure the USB Hub of the macbook Pro doesn't have the charging cable plugged into it
* Ran Macbook Pro on Battery only - same issue
I continue to throw money at this setup, (ie: waiting for a Topping D10s to show up to go Optical Out into the Modi, taking USB out of the chain again, looking at the Ebtech HumX, etc..) but really I could just go back to the SMSL SA50 and be dead quiet.. but then I get distortion at higher volumes - the 'lil guy just can't hold its weight.. plus I just love the look of the Vidar!
It seems that the USB power of any of these DACs is really spotty, and amplified from the Vidar somehow? Am I missing something obvious with how the Vidar is set up, or is Vidar just built in such a way that it's bringing out all these flaws with USB devices and EMI in general?
all insight is much appreciated!
